how to upload firmware to melzi v2 board? June 10, 2016 11:54PM |
Re: how to upload firmware to melzi v2 board? June 11, 2016 08:38AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: how to upload firmware to melzi v2 board? June 13, 2016 02:38AM |
Re: how to upload firmware to melzi v2 board? June 15, 2016 08:34PM |
Re: how to upload firmware to melzi v2 board? June 15, 2016 08:44PM |
Re: how to upload firmware to melzi v2 board? June 16, 2016 01:16AM |
Re: how to upload firmware to melzi v2 board? June 17, 2016 08:54AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: how to upload firmware to melzi v2 board? June 19, 2016 11:52PM |
Re: how to upload firmware to melzi v2 board? June 16, 2017 03:08AM |
Re: how to upload firmware to melzi v2 board? February 13, 2019 05:37PM |
Re: how to upload firmware to melzi v2 board? February 13, 2019 08:24PM |
Re: how to upload firmware to melzi v2 board? February 13, 2019 09:26PM |
Re: how to upload firmware to melzi v2 board? February 13, 2019 10:19PM |
Re: how to upload firmware to melzi v2 board? February 13, 2019 10:26PM |
Re: how to upload firmware to melzi v2 board? February 13, 2019 10:41PM |
Connect the AVR programmer to your PC, via USB. Connect the programmer to the Melzi, via the SPI pins. Connect USB to the Melzi - it needs power from the USB. Open Arduino IDE. Under 'Tools | Board' menu, select 'Sanguino W/ATmega1284p 16 mhz'. From the 'Tools | Serial Port' menu, select the port your AVR Programmer is on. From 'Tools | Programmer' select your AVR Programmer type. From 'Tools' menu, select 'Burn Bootloader'. You may receive an error; search the internet with the error message to troubleshoot what part isn't working properly. It mostly depends on the AVR Programmer you are using. Of course, there may also be a problem with your board.
Re: how to upload firmware to melzi v2 board? February 13, 2019 10:44PM |
Re: how to upload firmware to melzi v2 board? February 15, 2019 10:11PM |
Re: how to upload firmware to melzi v2 board? December 03, 2019 09:21AM |
Re: how to upload firmware to melzi v2 board? December 03, 2019 01:20PM |
Admin Registered: 11 years ago Posts: 3,096 |
davemaster
Greetings,
I just purchased this board, and have those motor connectors (4-pin). Where can I get those? What are these connectors name/code? Thanks in advance
