troubleshooting with TFT28 V1.2
Posted by jmn47
June 18, 2016 11:41AM
hi evrybody
i bought a MKS SBASE and a TFT28 V1.2 from China.
At first launch of the screen, it's work, the icon is in chinese.
But when i did the upgrade with the firmware on the SD card, the icon become blurred...
I'm tested all firmware from Github but it's the same thing.
Does someone have an idea to fix that?
thanks
(sorry for my english i'm french)
Re: troubleshooting with TFT28 V1.2
June 24, 2016 07:36AM
i have the MKS SBASE V1.2 but the pb not came from the MKS SBASE.
the screen is power supply without the SBASE, with 12V and i set the jumper on the rear of the TFT28 to 12v.
I don't need SBASE to update the firmware of the screen.
this is some exemple when i upgrade the firmware
the updating seems good, and the home screen is good too, it's just the button that is not displayed correctly
June 24, 2016 11:38PM
jmn47
Where did you find the firmware? The image you show is not from MKS own Github firmware.
At least none of my displays had that logo.
Did any of you modify your firmware?
Edited 1 time(s). Last edit at 06/24/2016 11:39PM by dintid.
My Instructables - both total newbie instructables and some for intermediate users.
My Designs on Thingiverse
YouTube channel containing a few 3D printing videos - they are videos for my Instructables, and mostly not standalone.
Ultius / Tantillus Thingiverse Group
June 25, 2016 02:57AM
yes it came from your own MKS Github, it's the french firmware...
i modify anything
this is with the english firmware V1.1.4
June 25, 2016 03:25AM
jmn47
i modify anything
Official Github Makerbase site:
[github.com]
Direct link to V1.1.4
[github.com]
If those were used I can only recommend talking to MKS via Aliexpress
Edited 1 time(s). Last edit at 06/25/2016 03:26AM by dintid.
June 25, 2016 03:26AM
i put the firmware with my raspberry pi and Ubuntu on the SD card.
It work's.....
so,to upgrade the firmware, do not use a Machintosh....
June 28, 2016 11:20AM
How to customize the menu? (not only additional 7 icons).
How to change font?
Where I can get IDE to make my custom menu?
June 29, 2016 12:47AM
karabas
How to change font?
Don't think you can. They have not published any pre-compiled firmware files.
Did you manage to make custom icons? When I create them bmp - .bin files using the small program they have put on github my MKS device just hangs.
June 29, 2016 06:29AM
dintid
karabas
How to change font?
No problem with selfmade icons. Just draw in photoshop or any PSD editor and convert to bin
I want rearrange all icons but not only last 7.
I want constant temp reading independent of navigating.
I want conditional assigning of my gcode to icons.
Current version is useless for me.
They do not realize if they go opensource everybody will buy MKS TFT display.
Until that even Nextion seems to be more useful.
June 29, 2016 06:49AM
karabas
dintid
karabas
How to change font?
I just realized it was the size that caused problems here. Wasn't aware of the different limitations.
320*240 is for logo (opening image)
78*104 is for icons.
You know how to assign 2 gcode commands to a single icon in the more section? Like raise hotend 20mm and then extrude 10mm filament? Should each command be seperated, or?
You should email the ones responsible for it. You find their email in the pdf with instructions on their Github site.
That said, you rather get what you pay for.. it's very cheap as it is. You can always read temperatures in Preheat menu.
June 29, 2016 07:53AM
dintid
I think as function in config ( didnot try myself)
# "Function" command line
> Function_btn1_cmd: M84;
> Function_btn2_cmd: G28; G29;
June 29, 2016 08:28AM
karabas
dintid
Yea, makes sense smiling smiley
You can by the way hide or show those two icons and change their functions if you like (I bet you allready knew that, but just wanted to say it anyway smiling smiley )
June 30, 2016 05:03AM
dintid
karabas
dintid
No I didnot, thanx. Now I have noticed display control lines in config smiling smiley
July 03, 2016 03:42AM
I found some really nice images from majurca and its on github now my LCD looks great.
https://github.com/majurca/MKS-TFT28-NEW-PICTURES
July 11, 2016 12:28PM
Updated mine to above buttons some are missing but i will go through it proper and see if i can fix them, i had trouble get the custom logo i edited after few tries done it but not perfect,
my tft is 32 version and found i had to save the file as a 16bit bmp then in the lcd program obviously 16bit width 320 height 240
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
July 11, 2016 04:46PM
I had hard time getting proper 16bit images from illustrator or other software's so found this software which can do it easily.
http://www.etrusoft.com/graphic-converter/index.htm
July 28, 2016 02:19PM
Hi everybody
I am happy that you like the images that I have done.
[github.com]
I also add some commands for bed leveling associated custom buttons.
September 03, 2016 12:23PM
Updated for firmware 1.1.4, all graphics/buttons available winking smiley
September 12, 2016 02:56AM
i can not change the logo.is that compulsory to make size of file must be 150k(bmp_logo.bin)
November 20, 2016 04:39AM
Hello.
I have just got one of these touch screens.
And the problem with it is under the images it's all in Japanese.
Would someone kindly give me a step by step on changing the images please.
Thanks in advance, wes
November 20, 2016 05:01AM
there is not step by step.
just download from the github the right version of the firmware onto the SD card's root and that's all
MKSTFT_V1.1.5_English is what you needdirect to the folder
majurca
Great work and thanks for sharing!!!
November 20, 2016 04:08PM
majurca
Hi everybody
[github.com]
Working for me also. Nice work and thanks.
So what do we use to convert the .svg to .bin? I'm using Ubuntu so pretty much any app will work but I can't find anything using Google so I must be asking for something which doesn't make since.
November 27, 2016 05:16PM
Hi, I found out Gibut Version 1.2.0
someone knows what implements from 1.1.5?
There is the possibility of the filament gearbox G-Code M600?
I am using MarlinKimbra.
I hope someone changes the icons of 1.2.0 that I find ugly.
Edited 1 time(s). Last edit at 11/27/2016 05:17PM by paolopa.
November 29, 2016 12:06PM
Hi guys,
I was playing with my custom bmp_logo and I can't make it work, even though I was following the steps from how to customize logo guide.
I have attached bmp version of logo. When use that Img2Lcd software as per instructions and upload to the tft28. If someone can tell me what I am doing wrong?
open | download - bmp_logo.bmp (76.1 KB)
November 30, 2016 07:50AM
I had trouble but i had to open paint and save it as a 16 bit bmp image for it to work also same settings as in the lcd2tft program
up and running
November 30, 2016 05:20PM
Thanks chriss
That did the trick. I was never too too comfortable with image file systems and definitions and now I am totally confused.
Why is it that softwares aren't in sync or am I wrong again? smiling smiley)
Anyways thanks a bunch. I am back to designing.
Cheers
January 03, 2017 07:23AM
I follow this post and it have helped me
So, now, i would like to make my own icons, but i don't arrive to use image2lcd... the image become white and black, and make error at firmware installation on mks tft
Anybody can help me please ?
January 30, 2017 08:41AM
do you have problem now with latest batch?
February 07, 2017 01:01PM
Hello majurca
Would you help with translation into Czech?
Source images remastered got me just put it in binary files.
  Sincerely, Edward
