Duet 0.8.5 + BLTouch June 18, 2016 05:48PM |
Re: Duet 0.8.5 + BLTouch June 20, 2016 03:51PM |
Re: Duet 0.8.5 + BLTouch June 20, 2016 06:02PM |
Re: Duet 0.8.5 + BLTouch June 20, 2016 08:23PM |
Re: Duet 0.8.5 + BLTouch June 21, 2016 06:22PM |
Re: Duet 0.8.5 + BLTouch June 22, 2016 03:03AM |
darkstargtk
I decided it would be easier go with an IR based solution so I ordered the differential IR sensor from Fillastruder - probably what I should have done in the first place... I'm not super excited about having to tear my PEI off of the glass and paint it.. I wonder if I can get away with painting the underside of the glass?
Re: Duet 0.8.5 + BLTouch June 22, 2016 03:10AM |
WZ9V
The same servo logic required for a servo deployed micro switch will also support the BLTouch. It uses the servo input signal to trigger the deployment of the pin the same way as a r/c servo would be used to raise/lower a micro switch.
Re: Duet 0.8.5 + BLTouch June 22, 2016 05:47PM |
Re: Duet 0.8.5 + BLTouch June 22, 2016 06:25PM |
WZ9V
I have not tried it at 3.3V or 5V yet.
I have one but its still in the box until I get my Delta back online. I guess I could try it with a spare RPi I have and let you know.
I've had nothing but trouble with FSR based nozzle probes. Don't know if it was my cursed machine or not. I'm rebuilding it with metal corners/carriages and dumping the FSR's in favor of trying a BLTouch. Thinking of dumping the wheels for linear rails but not sure about that yet.
Re: Duet 0.8.5 + BLTouch June 29, 2016 12:57PM |
dc42
...but before I turn it into a reality I need this hot end [deltaprintr.com] to be available in a 24V version.
Re: Duet 0.8.5 + BLTouch June 29, 2016 06:10PM |
KeepGettingTexts
dc42
Hi dc42,
I have thought about using that hotend as well. I too have a 24V system with 0.9 stepper motors. I have recently upgraded the fans on my cyclops and 24V power supply to 12V Noctua fans. The sound reduction is extremely noticeable. Anyway, I think a DC-DC SSR and one of these that I am currently using to power the fans. Will this cause any problems with the hotend PID being routed through an SSR instead of directly controlled via the Duet?
Re: Duet 0.8.5 + BLTou February 16, 2017 08:23AM |
dc42
The firmware on the Duet doesn't yet support servos. I don't recall anyone asking for it until about 3 weeks ago, probably because there are so many good contactless Z probe technologies available that nobody wanted to use the old servo-deployed microswitch type.
There is now an open issue about this, see [github.com]. Somebody has managed to get some degree of servo control by using the Fan 1 output and configuring suitable values for the frequency and PWM.
I don't have a BLTouch, and not only is is closed source, the manufacturer has applied for patents to protect it. This is completely the opposite of the spirit of RepRap. So supporting it will be a low priority for me, unless the manufacturer provides me with one for testing with and pays me a development fee. But unlike the BLTouch, RepRapFirmware is open source, so anyone can add support to it.
Re: Duet 0.8.5 + BLTou February 16, 2017 06:04PM |
Re: Duet 0.8.5 + BLTou February 17, 2017 01:58AM |
Admin Registered: 11 years ago Posts: 6,465 |
Re: Duet 0.8.5 + BLTou February 17, 2017 04:11AM |
Sorry. Guess I should stop posting from ipad when tired! I really didn't notice the timestamp and only found this by googling BLTouch and Duet WiFiQuote
dc42
dintid, until your post today the last post in this thread was 7 months old. A lot has changed since then. Servos are now supported in RRF, and there is a thread on the forum at duet3d.com on how to use bltouch with Duet.
Yea, I know. It's awesomeQuote
dc42
not to mention to whole forum dedicated to the duet.
