When i try to enable in the configuration
# network settings
network.enable true
Board stops working, lit only led D7
I try all the settings under # network settings - nothing changes.
File configutation.txt normal, if i set on same SD card "network.enable false" - then all starts to work.
Tried FW from MKS and the latest firmware from Smoothy.
I don't know what to try now!
Maybe someone knows a solution to this problem?
Maybe this has already been discussed on the forum? Please give a link.
