Ramps 1.4 Flaws still a issue?
August 10, 2016 06:29AM
In 2014 Thomas Sanladerer publish this [www.youtube.com] video on his youtube channel. In this video he is adressing 2 flaws that this board has. Is these flaws still an issue 2 years after?
The first thing he adressed was the polyfuses, that they are not strong enough, he recommended to use a automobil fuse instead. The seccond issue was the green power connectors that are made to take 10 amps only, and that they can overheat and melt. He recommended to solder the wires directly on the board.
Can any of you confirm if these issues still is a problem ? or maybe Tom himself if he read this.
I am very new to 3D Printing an bulilding a Prusa i3 Rework, have ordered a Ramps 1.4
Esimacio
Re: Ramps 1.4 Flaws still a issue?
August 10, 2016 07:38AM
If you shop around, and nope
In fact its now worse, with cheap board from china with connecters that are nothing like the correct spec, especially the heated bed. Some also supply crappy (not to spec) poly fuses.
Decent green connectors work fine, but people do silly thing, not screwing down the terminal hard enough, or soldering the cable ends (this make the connection worse)
You can now get the ramps 1.4.2 from limited suppliers, that has real fuses, but this board is limited to 12v, can't do 24 without replacing components
Edited 1 time(s). Last edit at 08/10/2016 07:39AM by Dust.
August 10, 2016 10:14AM
Thank you so much for responding to my questions. Well yes i did order from china, so what do you recommend that I do other than buying a new "real" one? I have in longer terms planned a Rambo instead of seperate Arduino and Ramps. Will I be able to use this board if I do some
improvment modifacations?
Esimacio
August 10, 2016 06:20PM
If you are on a tight budget, buy Arduino/RAMPS because nothing else is as cheap. If you can afford something better, go 32-bit.
February 04, 2017 04:13AM
The wiki claims the RAMPS project is still active but there hasn't been an update for years. Is there a group still working on it?
February 04, 2017 04:46AM
No. 8 bit is dead.
February 06, 2017 06:07AM
Dust
No. 8 bit is dead.
Maybe the Re-Arm project will re-animate the Ramps development...Wouldn't be surprised to see them making their own batch.
February 06, 2017 04:14PM
On the kickstater they mention "Custom Shields for the Re-ARM" though I haven't seen any further mention of this
February 12, 2017 02:17PM
Re-Arm might well keep the form factor going. There are some half decent ramps boards out there. I've probably had 5 or so the worst flaw I came across was the jumpers for microstepping being joined by traces which provided your only planning to use 1/16th then this isnt really a big problem. If you keep the heated bed current switching off the ramps board using relays (mech/SSR), then there is a lot less that can go wrong.
This UK supplier make a "premium" ramps board [ooznest.co.uk] but whether it really does anything better than a well made standard one I don't know. The real issue is that re-arm is £45 (plus shipping/tax) add a reasonable quality ramps board £15 = £60-£75 all in, so not too bad for a 32bit solution. If the ramps is going to cost £35 then you're into the territory of much better integrated 32bit boards. I can't see many people starting out with a new machine with 32bit in mind, going down the re-arm/ramps route. I bought one for the novelty and as I have a machine already running on arduino with ramps that I could swap it into it seems like a reasonable upgrade path.
I'd actually be surprised if Panucatt make a custom shield, after all aren't they selling Azteeg boards as well?
Edited 1 time(s). Last edit at 02/12/2017 03:12PM by DjDemonD.
Simon Khoury
Published:Inventions
February 13, 2017 03:35AM
DjDemonD
It's actually made in Spain (LINK) but to give full credit to Ooznest they haven't bumped up the price - it would cost the same if you bought it directly from the maker and paid the postage.
