hi
as the title says strange fault. long storey short .
the senor will only trigger if I use a different power supply from the 1 used to power the mks 1.4 . with a different 12v it works fine but with the mks1.4 boards 12v it wont trigger (but the light on the senor does light as it should ).
any advise welcome
cheers darren
I got a similar problem, the sensor works fine, the light goes on/off, and even changing the firmware detects open or close sensor, but when I try to use it, It doesn't detect it
