New 32 bits ARM MKS Robin with TFT??
Posted by Bobyni
October 24, 2016 07:17AM
Just saw a "NEW" card from M K S
[www.thanksbuyer.com]
Have anybody saw this or have ordered?
Edited 1 time(s). Last edit at 10/24/2016 08:19AM by Bobyni.
Re: New 32 bits ARM MKS Robin with TFT??
October 24, 2016 08:16AM
October 24, 2016 08:17AM
October 24, 2016 12:33PM
I've been on the maker base site and doesn't have this board on their site and not on the aliexpress shop they have so its hard to know what it supports
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
October 24, 2016 09:41PM
its a stm32 processor.. its running custom firmware [github.com]
Although they do provide binary updates, its completely closed source.
So if you have any issue, you have to talk to them. no 3rd party support.
November 01, 2016 03:38PM
chris33
I went to their chinese site and github and it is there.
I think they just lunched this board.
it is just put on Aliexpress but with very poor info there comparing the one found in taobao.com
Yes, it is a closed source, but I believe it is using smoothie.
Anonymous User
November 15, 2016 02:09AM
Hi
I receive Robin board,display and stepper drivers Motherboard support only 1 extruder, Second extruder is not presently supported in firmware.,All manual on GitHub are on Chinese language,Google translatte working fine,,Mks will sent me English version ,.Flashing firmware and set up is easy,Similar as flashing MKS Sbase smothie ,, Display flat cable is looking very gently, MB is not tested jet, Good price for ARM chip-set and big size TFT ,
November 15, 2016 02:43AM
grimlok2000
Hi
... Second extruder is not presently supported in firmware...
Is there a config file on the sd-card, where you could add the second extruder? There must be some way of adopting this board to your printer ( steps/mm, endstops a.s.o )
Anonymous User
November 15, 2016 04:11AM
config file is on sd card,,easy for change all value,,,,Motherboard firmware do not support dual extruder ,,In config file have 2 extruder seting and on board have 2 extruder connector,,,Frank Wei sent me massage that MKS expected change firmware begin of next year,,,For moment this is single extruder motherboard
CONFIG
############Óû§½çÃæÅäÖÃ#######################
>cfg_background_color 0x000000 #ÆÁÄ»±³¾°É«
>cfg_title_color 0xFFFFFF #±êÌâÎÄ×Ö
>cfg_state_background_color 0x000000 #ζȵÈ״̬±³¾°É«
>cfg_state_text_color 0xFFFFFF #ζȵÈ״̬ÎÄ×ÖÑÕÉ«
>cfg_filename_background_color 0x000000 #Îļþ°´Å¥ÉÏÎļþÃû×ÖÌå±³¾°É«
>cfg_filename_color 0xFFFFFF #Îļþ°´Å¥ÉÏÎļþÃû×ÖÌåÑÕÉ«
>cfg_printingstat_word_background_color 0x000000 #´òӡ״̬ÐÅÏ¢×ÖÌå±³¾°É«
>cfg_printingstat_word_color 0xFFFFFF #´òӡ״̬ÐÅÏ¢×ÖÌåÑÕÉ«
>cfg_BUTTON_3D_effects 0 #°´Å¥3DЧ¹û(0:ÎÞ,1:ÓÐ)
>cfg_Have_UPS 0 #»úÆ÷ÓÐÎÞ½ÓUPSµçÔ´£¨0:ÎÞ,1:ÓУ©
>cfg_language_type 3 #ÓïÑÔ(1:¼òÌåÖÐÎÄ;2:·±ÌåÖÐÎÄ;3:English)
>cfg_ui_set_maxtemp 260 #¼·³öÍ·ÏÔʾÆÁÉèÖÃ×î¸ßζÈ,²»Ó¦´óÓÚMAXTEMPÖµ
>cfg_ui_set_heated_bed_temp 120 #ÈÈ°åÏÔʾÆÁÉèÖÃ×î¸ßζȣ¬²»Ó¦´óÓÚHEATED_BED_MAX_TEMPÖµ
#ÉèÖýçÃæ×Ô¶¨Ò幦ÄÜ1ºÍ2
>setmenu_func1_display 1 #1:ÏÔʾ°´Å¥£¬0:²»ÏÔʾ°´Å¥
>setmenu_func2_display 0 #1:ÏÔʾ°´Å¥£¬0:²»ÏÔʾ°´Å¥
#ÿÌõÖ¸Áî±ØÐëÓ÷ֺÅ";"¸ô¿ª
>setmenu_func1:M84;
>setmenu_func2:G28;G32 S2;
>moreitem_pic_cnt 0 #"¸ü¶à"°´Å¥ÊýÁ¿
#°´Å¥1~°´Å¥7¶¨ÖÆÖ¸Áî
#ÿ¸ö°´Å¥ÉèÖÃÖ¸Áî×î´ó±ØÐëСÓÚ200×Ö½Ú
>moreitem_button1_cmd:G28 X0;G28 Y0;G28 Z0;
>moreitem_button2_cmd:G28 X0;G28 Y0;G28 Z0;
>moreitem_button3_cmd:G28 X0;G28 Y0;G28 Z0;
>moreitem_button4_cmd:G28 X0;G28 Y0;G28 Z0;
>moreitem_button5_cmd:G28 X0;G28 Y0;G28 Z0;
>moreitem_button6_cmd:G28 X0;G28 Y0;G28 Z0;
>moreitem_button7_cmd:G28 X0;G28 Y0;G28 Z0;
#############»úÆ÷²ÎÊýÅäÖÃ########################
>DRIVE_SYSTEM 0 #»úÆ÷ÀàÐÍ(0:xyz»úÐÍ£¬3:delta»úÐÍ)
>EXT0_TEMPSENSOR_TYPE 1 #¼·³öÍ·ÈÈ×èÀàÐÍ
>EXT1_TEMPSENSOR_TYPE 1 #¼·³öÍ·ÈÈ×èÀàÐÍ
>HEATED_BED_SENSOR_TYPE 1 #ÈÈ´²ÈÈ×èÀàÐÍ
>DELTA_MAX_RADIUS 115 #Èý½ÇÖÞÔ²»·°ë¾¶
>PRINTER_RADIUS 115 #´òÓ¡»úÖÐÐĵ½´¹Ö±Ö§³Å¸ËµÄ¾àÀë
>DELTA_DIAGONAL_ROD 300 #Èý½ÇÖ޸˳¤¶È
>DELTA_FLOOR_SAFETY_MARGIN_MM 15 #µ÷ƽ±ß½ç°²È«¾àÀë
>END_EFFECTOR_HORIZONTAL_OFFSET 28.5 #
>CARRIAGE_HORIZONTAL_OFFSET 25.50 #
>ROD_RADIUS 157.6 #
>BED_LEVELING_GRID_SIZE 5 #µ÷ƽ¼ä¸ô
>Z_PROBE_SPEED 80 #ZÖá̽ÕëËÙ¶È
>Z_PROBE_XY_SPEED 200 #XYËÙ¶È
>FEATURE_Z_PROBE 0 #µ÷ƽʹÄÜ,0:½ûÖ¹£¬1:ʹÄÜ
>BED_LEVELING_METHOD 0 #µ÷ƽ·½Ê½,0:3µãµ÷ƽ,1:¶àµãµ÷ƽ,2:4µãµ÷ƽ
>Z_PROBE_HEIGHT 39.91 #̽ÕëºÍÅçÍ·µÄ¸ß¶È²î
>Z_PROBE_X1 20 #Ô¤ÉèµÄ̽²âµã×ø±êX1
>Z_PROBE_Y1 20 #Ô¤ÉèµÄ̽²âµã×ø±êY1
>Z_PROBE_X2 160 #Ô¤ÉèµÄ̽²âµã×ø±êX2
>Z_PROBE_Y2 20 #Ô¤ÉèµÄ̽²âµã×ø±êY2
>Z_PROBE_X3 100 #Ô¤ÉèµÄ̽²âµã×ø±êX3
>Z_PROBE_Y3 160 #Ô¤ÉèµÄ̽²âµã×ø±êY3
>XAXIS_STEPS_PER_MM 78.74 #XÿmmµÄÂö³åÖµ,#ÈçÈý½ÇÖÞ»úÐÍ£¬XYZÂö³åÖµÉèΪһÑù
>YAXIS_STEPS_PER_MM 78.74 #YÿmmµÄÂö³åÖµ,ÈçÈý½ÇÖÞ»úÐÍ£¬XYZÂö³åÖµÉèΪһÑù
>ZAXIS_STEPS_PER_MM 400 #ZÿmmµÄÂö³åÖµ,ÈçÈý½ÇÖÞ»úÐÍ£¬XYZÂö³åÖµÉèΪһÑù
>EXT0_STEPS_PER_MM 90 #E0ÿmmµÄÂö³åÖµ
>MAX_FEEDRATE_X 200 #XÔ˶¯µÄ×î´óËÙ¶Èmm/s
>MAX_FEEDRATE_Y 200 #YÔ˶¯µÄ×î´óËÙ¶Èmm/s
>MAX_FEEDRATE_Z 20 #ZÔ˶¯µÄ×î´óËÙ¶Èmm/s
>MAX_FEEDRATE_EXT0 50 #E¼·³ö»úµÄ×î´óËÙ¶Èmm/s
>MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000 #X·½ÏòµÄ´òÓ¡×î´ó¼ÓËÙ¶Èmm/s^2
>MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000 #Y·½ÏòµÄ´òÓ¡×î´ó¼ÓËÙ¶Èmm/s^2
>MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100 #Z·½Ê½µÄ´òÓ¡×î´ó¼ÓËÙ¶Èmm/s^2
>MAX_ACCELERATION_EXT0 3000 #E¼·³ö»úµÄ´òÓ¡×î´ó¼ÓËÙ¶Èmm/s^2
>MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000 #XÖáÒƶ¯×î´ó¼ÓËÙ¶Èmm/s^2
>MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000 #YÖáÒƶ¯×î´ó¼ÓËÙ¶Èmm/s^2
>MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100 #ZÖáÒƶ¯×î´ó¼ÓËÙ¶Èmm/s^2
>HOMING_FEEDRATE_X 40 #X¹éÁãʱµÄ¹éÁãËÙ¶È
>HOMING_FEEDRATE_Y 40 #Y¹éÁãʱµÄ¹éÁãËÙ¶È
>HOMING_FEEDRATE_Z 10 #Z¹éÁãʱµÄ¹éÁãËÙ¶È
>MIN_EXTRUDER_TEMP 150 #Ö÷°å¼·³öÍ·×îµÍζȣ¬Æð±£»¤×÷ÓÃ
>MAX_EXTRUDER_TEMP 275 #Ö÷°å¼·³öÍ·×î¸ßζȣ¬Æð±£»¤×÷ÓÃ
>MAX_HEATED_BED_TEMP 150 #Ö÷°åÈÈ°å×î¸ßζȣ¬Æð±£»¤×÷ÓÃ
>NUM_EXTRUDER 1 #ÅäÖü·³öÍ·¸öÊý
>HAVE_HEATED_BED 1 #1£ºÊ¹ÄÜÈÈ´² ,0£º½ûÖ¹ÈÈ´²
>INVERT_X_DIR 1 #X²½½øµç»ú·½Ïò
>INVERT_Y_DIR 0 #Y²½½øµç»ú·½Ïò
>INVERT_Z_DIR 1 #Z²½½øµç»ú·½Ïò
>EXT0_INVERSE 0 #E²½½øµç»ú·½Ïò
>X_HOME_DIR -1 #»ØÁãʱ·½Ïò(-1:×îС·½Ïò£¬1:×î´ó·½Ïò)
>Y_HOME_DIR -1 #»ØÁãʱ·½Ïò(-1:×îС·½Ïò£¬1:×î´ó·½Ïò)
>Z_HOME_DIR -1 #»ØÁãʱ·½Ïò(-1:×îС·½Ïò£¬1:×î´ó·½Ïò)
>X_MAX_LENGTH 210 #X×î´óÐгÌ
>Y_MAX_LENGTH 210 #Y×î´óÐгÌ
>Z_MAX_LENGTH 180 #Z×î´óÐгÌ
>X_MIN_POS 0 #X×îСÐгÌ
>Y_MIN_POS 0 #Y×îСÐгÌ
>Z_MIN_POS 0 #Z×îСÐгÌ
>ENDSTOP_X_MIN_INVERTING 1 #XÖá×îСÏÞλȡ·´ÉèÖÃ
>ENDSTOP_Y_MIN_INVERTING 1 #YÖá×îСÏÞλȡ·´ÉèÖÃ
>ENDSTOP_Z_MIN_INVERTING 1 #ZÖá×îСÏÞλȡ·´ÉèÖÃ
>ENDSTOP_X_MAX_INVERTING 0 #XÖá×î´óÏÞλȡ·´ÉèÖÃ
>ENDSTOP_Y_MAX_INVERTING 0 #YÖá×î´óÏÞλȡ·´ÉèÖÃ
>ENDSTOP_Z_MAX_INVERTING 0 #ZÖá×î´óÏÞλȡ·´ÉèÖÃ
>MIN_HARDWARE_ENDSTOP_X 1 #ʹÄÜXÖá×îСÏÞλ
>MIN_HARDWARE_ENDSTOP_Y 1 #ʹÄÜYÖá×îСÏÞλ
>MIN_HARDWARE_ENDSTOP_Z 1 #ʹÄÜZÖá×îСÏÞλ
>MAX_HARDWARE_ENDSTOP_X 0 #ʹÄÜXÖá×î´óÏÞλ
>MAX_HARDWARE_ENDSTOP_Y 0 #ʹÄÜYÖá×î´óÏÞλ
>MAX_HARDWARE_ENDSTOP_Z 0 #ʹÄÜZÖá×î´óÏÞλ
>min_software_endstop_x 0 #ʹÄÜXÖá×îСÈíÏÞλ
>min_software_endstop_y 0 #ʹÄÜYÖá×îСÈíÏÞλ
>min_software_endstop_z 0 #ʹÄÜZÖá×îСÈíÏÞλ
>max_software_endstop_x 1 #ʹÄÜXÖá×î´óÈíÏÞλ
>max_software_endstop_y 1 #ʹÄÜYÖá×î´óÈíÏÞλ
>max_software_endstop_z 1 #ʹÄÜZÖá×î´óÈíÏÞλ
November 17, 2016 06:11AM
The TFT would be ok, if it was more functional than eye candy, don't get me wrong I have a tft32 but there is a lot more they could add to it to make it nice and useful. A mini keyboard for one as you could submit g-codes manually so for instance on a delta I did a G32 or changed a setting I could M500 from the screen in standalone, also the report back the result of calibrations to
up and running
Anonymous User
November 17, 2016 11:04AM
All reconnected.and all working OK now ,
Edited 3 time(s). Last edit at 11/17/2016 10:34PM by grimlok2000.
November 17, 2016 12:43PM
grimlok2000
i run in trouble....Board flashing pass easy but temperature reading for extruder and hot bed are -42 celsius,,what ever i change nothing is happening,,,when all thermistor are disconnected it have same -42 celsius,,,,On display extruder is marked as E1 Must be E0 ..I sent message to Frank Wei ,,,I think board will go back to Makerbase ,
I'd claim an issue with Makerbase, but keep the board until it is clearly an hardware error. Might just be a wrong pin mapping in firmware...
November 18, 2016 12:02AM
We have MKS Robin on our site and on the aliexpress shop, you can land tis website to know more informmation ahout MKS Robin: [www.aliexpress.com].
November 18, 2016 12:08AM
Yes, if you want to kown more information about MKS Robin, you can land this website: [github.com], otherwise, you can ask the customer service of Makerbase on Aliepress.
November 18, 2016 12:14AM
Yes, the MKS Robin just supports 1 extruder E0 now, but we are going to realise a new firmware supporting two extruder EO, E1 as soon as possible.
November 18, 2016 12:18AM
Yes, we are going to release a new firmware supporting two extruder and more functions.
November 18, 2016 12:21AM
Very happy to hear that.
November 18, 2016 12:31AM
Do you whether connect the thermistor? Robin board is -42 ℃ if it is not connected the thermistor.
Anonymous User
November 18, 2016 02:44AM
it is working fine...i re-connect all cable and use new thermistor ,,all is ok now
Edited 1 time(s). Last edit at 11/18/2016 02:44AM by grimlok2000.
November 20, 2016 05:14AM
:-( I was the first one to discovered the board, and the fifth in purchase it from TaoBao,
but still waiting my board to arrive after long issue with the shipping and finally got it shipped out thanks to the intervention from Aliexpress' Ms Zhong
still waiting my Sbase board as well......
sad now..
Anonymous User
November 20, 2016 09:07AM
Makerbase official Aliexpress shop
All ordered on link above was delivered in less than 10 days.Nice and safe packing, fast replay and respond when you need help,
My Robin is connected and working fine,
November 20, 2016 06:52PM
grimlok2000
Lucky you!!!
where you are located? i'm in Canada and still waiting ... last updated was on Oct 28 for the Sbase and the Robin was Nov 04....:-(
November 23, 2016 12:14PM
For those of you that have this board how is it? Any pros cons vs. a mks sbase or base board?
November 24, 2016 04:07AM
As soon as someone ports it to an open source firmware, you have board & TFT for an unbeatable price, but until then....
November 26, 2016 01:06AM
It's our honor to serve for you,sincerely hope we can deal with you next time.
November 26, 2016 05:34AM
flyway97
I gather your with mks and i do keep messaging frank on aliexpress but get very vague replies, My issues are with the tft lack of capabilities and potential it could have there is no way for anyone to develop more functional actions on it not just to able to changing the button images, the config i can't read proper as its half Chinese and English, im trying to change my tft sayin i have e1 when it should say e0 but hard to read the Chinese titles of the functions, it would be nice to see a way to put a qwerty keyboard and a way to manually put gcode in
up and running
Anonymous User
November 27, 2016 04:44AM
Extruder is on display is E1, when connect first time i have -42 celsius reading I have connect to E0 for heater cartridge and E1 for thermistor, On display missing many icon comparing with tft2,8" can not get autolevel , This days I will need to order one more motherboard ,,Smotiebord Sbase and 2,8 tft looking much better option.I have 2 Sbase working perfect ..Mks Robin is cheaper option but need more developing for firmware,This is not open source and not supported by community,,Some thing you must do it yourself or wait for Markebase team.
Edited 3 time(s). Last edit at 11/27/2016 09:41AM by grimlok2000.
Anonymous User
November 29, 2016 02:06PM
new firmware and config complete on english lenguage is posted today on MKS Github page
[github.com]
Edited 1 time(s). Last edit at 11/29/2016 02:40PM by grimlok2000.
open | download - robin_config.txt (6 KB)
Anonymous User
December 06, 2016 11:04AM
this board is pain in the ass,
in begin i did not have temperature readings ,,no possible ti invert stepper motor direction ,,,it is single extruder board .second extruder is not opertional..extruder on display is E1 but working connected to E0 and TH1
i use new config full on english language posted on GitHub . all direction of en stops and stepper motor s are now correct,homing going to minimum,motors workig correct direction
now i have new issue,,i want set 32 micro steps ,,,i have correct double value for steps X180/Y180/Z800/E1 180 (200 steps x 32 microstep x 20 teethx gt2 pulleypich ,Gt2 belt as per prusa calculator and personal experience) and correct size of movement after homing 300mm x200mmx 400mm ,stepper driver jumper are correct connect for 32 microsteps ,,,
printer use only half of hot bed, changing any valuein config file and resetting board do not give any change,,
changing config and flashing new firmware give no change,,,
changing 8gb sd card received with board no give any change,,
,i am piss of and today i am going to scrap Robin board and replace with some reliable community supported board,,,
Markerbase did not respond to my mail,,,No support from MKS no support from community,,this forum is only place where you can find any info..not so much
if you have 65 usd for trow in garbage go forward and buy MKS Robin
December 07, 2016 12:36AM
Yes, MKS robin works with TFT.It's a kit selling on Aliepress include Robin board and TFT display.
