Hello,
I've purchased a RUMBA board designed for the BIQU printer. It seems to work fine, but I cannot heat the bed.
The board is powered on the "main-pwr" and "hb-power", and the bed is plugged on "HB-out". I use the Marlin firmware (stable 1.0.2-2), you can see my config file attached.
I am used to use a RUMBA board, I already had an original RUMBA from RepRapDiscount (which is died, because of a lightning...), but maybe my new board don't works the same way?
Edit: It was just a mistake, I plugged the bed therm on the wrong pins (t1 instead of thb). Now it works
Edited 1 time(s). Last edit at 11/01/2016 04:32PM by kimented_.
Prusa i3 - e3d v5 - Gnu/Linux - Pronterface - Slic3r - Octoprint - Rpi - French
