Odd Temp Sensor behavior January 27, 2017 08:28PM |
Re: Odd Temp Sensor behavior January 28, 2017 10:41AM |
Re: Odd Temp Sensor behavior January 30, 2017 09:22AM |
Re: Odd Temp Sensor behavior January 30, 2017 09:17PM |
SENT: M140 S50 READ: ok SENT: M104 S215 T0 READ: ok SENT: M105 READ: ok T:15.0 B:15.9 SENT: M105 READ: ok T:15.0 B:16.3 SENT: M105 READ: ok T:15.8 B:16.8 SENT: M105 READ: ok T:17.7 B:17.3 SENT: M105 READ: ok T:20.5 B:17.5 SENT: M105 READ: ok T:24.1 B:17.9 SENT: M105 READ: ok T:28.1 B:18.3 SENT: M105 READ: ok T:32.6 B:18.7 SENT: M105 READ: ok T:36.9 B:19.0 SENT: M105 READ: ok T:41.3 B:19.4 SENT: M105 READ: ok T:45.6 B:19.9 SENT: M105 READ: ok T:49.8 B:20.2 SENT: M105 READ: ok T:54.0 B:20.7 SENT: M105 READ: ok T:57.9 B:21.0 [Cut a bunch for compactness] SENT: M105 READ: ok T:146.0 B:29.9 SENT: M105 READ: ok T:148.3 B:30.3 SENT: M105 READ: ok T:150.5 B:30.5 SENT: M105 READ: ok T:152.6 B:30.8 SENT: M105 READ: ok T:154.7 B:31.1 SENT: M105 READ: ok T:156.8 B:31.6 SENT: M105 READ: ok T:158.4 B:31.6 SENT: M105 READ: ok T:160.1 B:32.0 READ: Error: heating fault on heater 1, temperature rising much more slowly than the expected 1.2°C/sec SENT: M105 READ: ok T:B:32.4 SENT: M105 READ: ok T:B:32.6 SENT: M105 READ: ok T:B:32.9 SENT: M105 READ: ok T:B:33.2
Re: Odd Temp Sensor behavior January 31, 2017 02:28AM |
Re: Odd Temp Sensor behavior January 31, 2017 10:05AM |
Re: Odd Temp Sensor behavior January 31, 2017 01:09PM |
Re: Odd Temp Sensor behavior February 01, 2017 08:13PM |
SENT: M307 H1 READ: Heater 1 model: gain 538.2, time constant 228.7, dead time 11.9, max PWM 1.00, mode: PID READ: Setpoint change: P6.4, I0.028, D53.1 READ: Load change: P6.4, I0.224, D53.1
SENT: M105 READ: ok T:239.6 B:17.6 SENT: M105 READ: ok T:240.1 B:17.8 READ: Auto tune of heater 1 with P=0.50 S=240.0 cancelled because temperature limit exceeded. Use lower P or higher S in m303 command. SENT: M105 READ: ok T:B:17.9 SENT: M105 READ: ok T:B:17.6 SENT: M105 READ: ok T:B:17.8
Re: Odd Temp Sensor behavior February 01, 2017 08:59PM |
SENT: M105 READ: ok T:225.9 B:16.1 SENT: M105 READ: ok T:226.0 B:15.8 READ: Warning: Heater 1 appears to be over-powered and a fire risk! If left on at full power, its temperature is predicted to reach 567C. READ: Auto tune heater 1 with PWM=0.40 completed in 648 sec, maximum temperature reached 226.0C READ: Use M307 H1 to see the result SENT: M105 READ: ok T:B:16.0 SENT: M105 READ: ok T:B:16.0 SENT: M303 READ: Heater 1 tuning succeeded, use M307 H1 to see result READ: ok SENT: M105 READ: ok T:B:15.9 SENT: M105 READ: ok T:B:16.0 SENT: M105 READ: ok T:B:16.0 SENT: M307 H1 READ: Heater 1 model: gain 547.2, time constant 231.8, dead time 6.8, max PWM 1.00, mode: PID READ: Setpoint change: P11.1, I0.048, D52.9 READ: Load change: P11.1, I0.594, D52.9 READ: ok SENT: M105 READ: ok T:B:15.8 SENT: M105 READ: ok T:B:16.2
Re: Odd Temp Sensor behavior February 02, 2017 05:07AM |
Re: Odd Temp Sensor behavior February 03, 2017 08:05AM |
Re: Odd Temp Sensor behavior February 03, 2017 09:39PM |
