tft28 V1.3 not working with Ramps 1.4
February 02, 2017 09:59PM
Ok so I have verified the configuration file powered with external 12v power supply and updated the firmware to English and adjusted the baud rate to all 4 settings with resets in between but I cannot get this screen to work with my ramps board. is there anything I am missing?
1. loaded firmware
2. plugged into ramps aux1 port
3. adjusted baud rate
4. reset
5. still not working.
Re: tft28 V1.3 not working with Ramps 1.4
February 03, 2017 01:53AM
ramps must be set to serial 0 in firmware (you may have moved it, for say a bluetooth setup)
Find out what your serial is actually set to, don’t guess. (and you may have set it to something non tft28 compatible)
Don't have the usb cable connected to the ramps, its the same serial port the tft28 uses.
February 03, 2017 08:58AM
I will check where is the serial Info located in marlin. Is it configuration.h or in the pins section.
February 03, 2017 11:02AM
Ok so serial port is zero adjusted baud rates in firmware. issue remains the USB isn't connected at all have reset both but still no communication
If it helps the screen is ver1.3
Edited 1 time(s). Last edit at 02/03/2017 11:19AM by Travb1999.
February 03, 2017 06:11PM
sounds like you have done everything you can... its a dead screen. return to seller.
February 03, 2017 06:23PM
just getting the label printed now thanks for your help all.
February 05, 2017 01:48AM
Did you google on the older version of this TTF touch screen?
my memory could fail me, but I think it was that the cable that goes to the RAMPS has to be reversed....
just dble check....
good luck
