Azteeg X1 3DP with lcd & SD control board
Posted by ju de tomate
April 12, 2017 03:45AM
Hi
I am looking for information about connecting a lcd & SD control board like this : [www.ebay.com]
to a a Azteeg X1 3DP.
I imagine that we can use ext pin and uSD pin as attached :
Thanks in advance for your help.
Re: Azteeg X1 3DP with lcd & SD control board
April 12, 2017 04:46AM
That control board may have a 644p, that’s in sufficient for a glcd, basic marlin firmware with glcd and sd enabled is uses 100,448 bytes
because this is a dot matrix ie 128 x 64 pixels, all fonts, graphics and the code to drive it has to be in the control board firmware.
April 12, 2017 06:10AM
I am not sure to understand.
You speak about required memory. There is enough memory, isn't it ?
April 12, 2017 06:22AM
that board can have either 644p cpu or 1284p cpu the difference is 64Kbyte or 128Kbyte of Flash program memory
64Kbyte is to small to hold the needed 100+Kbyte firmware
Take a close look at the main chip on your board, it will have a number on it. 1284p or 644p
April 13, 2017 03:04PM
Ok thanks for the explanation.
I took a picture :
I can not sew this number!
April 13, 2017 03:39PM
The number is on the top chip, 1284P.
April 13, 2017 04:16PM
So I can do it ! great !
April 14, 2017 07:32AM
So no we know the firmware can fit... so that is the first question answered
Many many other questions.. remain
Next is how many i/o pins does the glcd need and are there enough on the available connectors...
(Ive seen this around but cant find it quickly, but the board looks like iy used standard reprap connectors )
from [3dprintingdatabase.org]
and [files.panucatt.com]
we see that exp1 and exp2 and sd ramps connectors are well documented.
Also have you ever compiled your own firmware? as you going to need to after defining the required pins for the glcd.
April 17, 2017 11:03AM
just joining in with the reprap discount glcd ad the X5GT...is it really that hard to find what pin/line from the Display corresponds to which pin on the Controllerboard?
I find stuff like
[chibidibidiwah.wdfiles.com]
[www.opensourcelab.salazarserrano.com]
but still no clue where anything besides the killswitch and the power suply is going
