MKS TFT Icon problems
Posted by mrcshbs
April 16, 2017 04:26PM
Hello
I have a MKS TFT 3.2 inches and no matter what firmware I upload, I get the same results... Some icons simply don't want to show correctly. All the other icons show correctly.
This is the Original 2.0 MKS TFT... I downloaded and some icons do not show up correctly
[github.com]
I also tried the version 1.2 (same results)
[github.com]
Lastly, I also downloaded an alternative firmware for Majurca (same results) some icons look messed up.
[github.com]
I open the config files in Notepad with Windows 10... but doesn't matter if I make any modifications on the config file or not. the icons still don't work.
so, I thought maybe it was a bad LCD MKS, so I bought another one... still same results on the new one.
Is there any tricks or something when updating the firmware? right now, I have it connected to the MKS board and gets power via the ribbon cable. The 2.8 inch has a 12V plug but the 3.2 inches does not.
Any ideas?
Please see attached images.
I followed this thread here with no success:
[forums.reprap.org]
open | download - 1.jpg (202.2 KB)
open | download - 2.jpg (176 KB)
open | download - 3.jpg (180.7 KB)
open | download - 5.jpg (200.3 KB)
Re: MKS TFT Icon problems
April 16, 2017 04:51PM
Please disregard this thread.
Problem solved. Here is the solution:
If after you upload the firmware, you experience the same problem, use a SD card (not the UScool smiley but the SD card must be smaller than 4GB.
I used an old 512MB SD card and when I uploaded the original firmware from the site (same one I was having problems with) it worked like charm!
So conclusion: Use a smaller than 4GB SD hard when uploading the firmware to the MKS TFT 2.8 or 3.2
Thanks
Marcos.
