lerdge board 32 bits
Posted by titeuf007
Re: lerdge board 32 bits
November 19, 2017 10:14AM
The above wifi board is not Lerdge's wifi board. They haven't released it yet.
November 19, 2017 10:55AM
are far behind with development.
they are using us as a tester
bad Chinese sellersangry smiley
total disappointment await their timethumbs down
i think i sell my 2 cards
so I think it's a failed project
we talk about a new board besides the Lerdge X
Edited 3 time(s). Last edit at 11/19/2017 11:00AM by maralb.
DELTA Printer - Alligator board - Server Repetier Touch - E3D_V5
November 19, 2017 12:17PM
Alberto
Nobody want to buy this crappy board ,Wish you luck in selling,Better sell separate TMC drivers and try to sell naked board ,
,A year ago Lerdge publish wifi module and fast widraw when found bug ,Promise fix problem soon and nothing happened for past year ,Lerdge forum on official page is dead, Any way Lerdge did not participate in discussion and i never observe administrator reply , Never take any action to achieve customer request, Like change set point for auto PID ,or explain USB connectivity. Real support do not exist ,
Publishing new module and firmware develop is slow down or complete stopped,New X motherboard and -S firmware are different,They start selling X motherboard but firmware is not available for download on official page.
You are correct ,Lerdge use own customer as tester,,,I test for them first sold dual extruder module, Juculijan test SSR and 220 v silicone pad, some people test Hot bed Mosfet ,some people overheat processors in first version , Do not forget we give 120 usd or more to have privilege to test Lerdge board .Result of our testing X board have external hot bed module and new processos,not supporting dual extruder module,
I sent my burned board to dalta3d long time ago,Never have any news why board burn .never reply after i sent board, Lerdge style .
It is Chinese selling company grabbing your money and then you are alone.
if you need brand new Lerdge display i have one in stock
PS,,i wonder if Ian will react like he do on FB
Edited 2 time(s). Last edit at 11/19/2017 02:25PM by edvard rahel.
November 25, 2017 08:16AM
Lerdge forum is back online,All international user are deleted, All post on English disappeared,Only chinese crap found there an 9 Chinese user, No any help or support, This topic is dead,Joint to FB Lerdge group is wasting time,Lerdge forum gone
I am selling new Lerdge s board and 4 LV8729 drivers for 60 usd on Ebay.USA free shipping,,
Forum for Chinese
[bbs.lerdge.com]
November 25, 2017 08:54AM
the Lerge group also makes mistakes with the new board X.........
look at the photo of Heatbed Extended
4 pin for optional module connection
look at real photo, 3 pin
angry smileyangry smileyyawning smileyconfused smiley
4pin adapter
hot smiley
Edited 2 time(s). Last edit at 11/25/2017 08:58AM by maralb.
November 25, 2017 09:55AM
it is 4 pin from board to hot bed adapter than 2 wire to power mosfet module,,hot bed thermistor to bed adapter,,,,Firmware for X board is different than S board but no download available on large web,
What is point to make miniature size of board and than connect 2 module same size as board.
I just instal MKS Gen1,4 to printer i build,,,It is small,,have 2 extruder,big hot bed mosfet, usb on board ,supporting TMC 2100 drivers on 1/256 and Lv8729 on 1/32 stepps ,using open source firmware Marlin or Repetier ,big community support, and it cost 20 usd .
Edited 2 time(s). Last edit at 11/25/2017 10:08AM by edvard rahel.
November 25, 2017 11:51AM
there are only 3 pins on the Lerge X
you see from the photosconfused smiley
November 25, 2017 12:20PM
Edited 5 time(s). Last edit at 11/25/2017 12:50PM by edvard rahel.
January 29, 2018 11:35AM
Hello!
I have the lerdge board for some months for now and this is a love-hate relationship... well, mostly hate.
The board is in a CoreXY machine. 2xTMC2100 for X/Y and 2xA4988 for Z and E.
Today I changed the 4988s to DRV8825s. When I move Z or E it makes a lot of vibration, high pitch noise and clicking sound from the motors.
Why can this happen? Anybody uses DRV8825 with Lerdge board help please. Thank you!
January 29, 2018 03:52PM
Have you checked the vref on the drivers. Sounds like it will need dropping
January 31, 2018 03:36PM
Hello!
I checked the Vref and set it to 0,9V (1,8A motors) it sounds better, but still pretty unhealthy.
February 17, 2018 03:19AM
Hello. The settings item is missing from the OSD menu. New firmware doesn't help. How can a hardware reset Lerdge-X.
February 24, 2018 04:53PM
Hello,
I downloaded from lerdge.com the latest firmware (X V1.0.3) and copy the memory card. Connect the card and start the update. The update is complete 100%, after restart and the following message: "Checking the user UI... Plaese wait..." and wait and wait and nothing is happening.
If I disconnect the memory card error message that you can not find the UI file.
The UI file folder: Lerdge_system\UI\Lerdge_X_UI_V1.0.3.ui
What is the problem?
February 25, 2018 10:20AM
system files must be in root on sd card ,,instructions
Note: Do not modify the file name or file path ! ! ! ! ! !
1 "Lerdge_system" copy the entire folder tothe TF card or U disk root directory (must be the root directory, or may appear
to find the UI file problem
May 24, 2018 10:08AM
[youtu.be]
[youtu.be]
need scara setup but there is a lock on scara setup
need help
June 26, 2018 02:22AM
I bought and installed the Lerdge S and replaced the ramps board, My issue is the temperature of the hot end is 70 C to cold so I have to use 275 to print PLA. my other issue I do not like is after it homes Z it goes to X0,Y0 and Z0 left front of bed instead of staying in the center, when it starts to print it drags the hotend across the bed to start printing, so with no extruding going on it is not good for the hotend tip. even changing the settings in lerdge.config file and uploading it still does not do right like the ardunio/ramps controller. we need more controll in the lerdge.config , like tempature offset and bed setup.
M206 X195.000 Y195.000 Z10.000
;X:X-axis thermal head after homing with the theoretical origin offset
;Y:Y-axis thermal head after homing with the theoretical origin offset
;Z:Z-axis thermal head after homing with the theoretical origin offset
open | download - 20180528_125412.jpg (665.9 KB)
June 27, 2018 08:11PM
[youtu.be] - FW V2.0.6 work normally but on V2.0.8 I have problem with touchscreen
June 27, 2018 11:01PM
Touch screen works fine, it the hotend temptature and no line in the config fig to offset it.i ordered the thermomister at lerdge Ali store.
