CNC Shield V3 + Arduino Uno R3, Heater
Posted by caslor
May 23, 2017 04:42AM
Hi
I want to use the teacup firmware with Arduino Uno and a CNC shield V. 3 board
In the configuration file of the board for the heater in extruder has only to choose the AI03 pin that is an analog pin in Arduino uno
In the other hand as far as I know in order to connect and control the heater element (needs 12v supply) you need to connected through a Mosfet and a Pwm pin of an arduino..
Allah the configuration files I have seen until know for this board they have standard the AI03 pin for the heater..
So I wonder.. Have I understand something wrong about the Pwm and Mosfet? Can I use the AI03 (analog) with the Mosfet also?
Thanks in advance
Edited 1 time(s). Last edit at 05/23/2017 11:10AM by caslor.
Re: CNC Shield V3 + Arduino Uno R3, Heater
May 24, 2017 11:35AM
ok after some experiments with mosfet and arduino + heater i saw that for the heater it is not necessary to be connected in a PWM pin as it just open and close the voltage to achieve target temperature .
so Analog pin can work also for heater extruder
