Alternative for the H21LOB Opto
Posted by NJC
NJC
March 21, 2011 09:40PM
I have just started building a Prusa Mendel (have ordered almost all the parts!) and am now to the point where I need to buy the Optos. I have decided to go with the Gen6 electronics and cannot seem to find the H21LOB optos anywhere but mendel-parts.com. According the Mouser and Digikey, this part is now obsolete.
I was wondering if anyone knew of any alternatives to this that are compatible with the Gen6 design (and firmware) so I do not need to change any schematics or code? Has anyone else run into this problem?
I saw that the TCST2103 should be compatible but the wiring would need to be different. I cant find any documentation showing how the wiring would need to be done.
Thanks for any help!
Edited 1 time(s). Last edit at 03/21/2011 11:05PM by NJC.
Re: Alternative for the H21LOB Opto
March 22, 2011 08:17AM
Here are instructions on how to tweak the Gen3 Endstop, should work for the TCST2103 as well: [reprap.org]
Gen6 has endstop electronics on the main board, so you'll have to apply your Dremel there.
NJC
March 22, 2011 10:58AM
Thanks for the link! Earlier this morning I actually found that the Gen6 firmware has a version specifically for the TCST2103, so I think it will work just fine.
March 23, 2011 02:59AM
The H21LOB is available just fine from ebay tongue sticking out smiley VV
reprapworld.com
PLA, ABS, PETG multiple colors (3 and 1.75 mm) €16,49 / kg
Megatronics 3.0 €79.99 / Minitronics €37,19
March 07, 2012 05:09PM
Hi see my other thread Hope it helps
