New (4) Stepper Driver Board!
Posted by Andrew Diehl
March 28, 2011 10:29PM
I just finished assembling the first prototype. Works perfectly so far, no magic smoke!
It's a remake of the A4983 chips used on the pololu stepper driver board. The difference is there are built in microstepping selectors, reverse polarity protection, and indicator led's for logic power, driver power, and step inputs. All the parts are 0803 or larger for reliability. Lots of space was left around the chips so a single long heat sink could be mounted over all the driver chips if desired, and there is generous copper on the bottom of the board for further heat dissipation. Boards are professionally assembled with a pick and place machine and conveyor reflow oven.
With any luck I'll have this board integrated with an atmega 328, some mosfets, and thermocouple/thermistor inputs next month.
Would anyone (preferably in the US) be interested in helping me test a few of these out on working repraps? It will work with any board that outputs step and direction signals, +5v, and +8 to 24V for driver power.
I'm planning on doing some more testing to be reasonably assured they will work perfectly, before building up the rest of the boards I have.
Once the design is finished i'll do a wiki entry including the eagle files to keep sebastian happy smiling smiley
Comments welcome!
Edited 1 time(s). Last edit at 03/29/2011 12:49AM by Andrew Diehl.
open | download - Driver Board.jpg (555.4 KB)
Re: New (4) Stepper Driver Board!
March 29, 2011 04:26AM
Hi Andrew
That's a nice layout, good job.smileys with beer
It maybe nice to have a local 5v regulator option so you don't need to route it from the main-board (if it's being used separately).
Add some holes along the row of A4983's so as you say a sprung heat-spreader can be fixed across all of them.
Think about making your motor connections 0.156" it looks like they are 0.1" at the moment?
If you have space around the dill switches put the stepping settings on the silk-screen
Also add + and - to the silk screen for the pot (motor current) people always turn them the wrong way.
Do you have a PTC resettable fuse?
Think about routing the REF pin to a spare connector - I always fancied reading this voltage on the main-board so you can report the current being set by the pot on each channel.
Maybe you could also set the current limit for each channel in software if you have a few spare pins to control a simple resistor ladder. - I'll have to try that.
Other than that, think about making a 5 channel layout (E2) smiling bouncing smiley or just make a single channel version for future expansion.
I did a few similar little expansion channels with dill switches etc. in the RAMPS style -
It's a shame your in the US, I would really like to help you test it - if I can help in any way, just let me know.
Good luck with it.
Rich.
[richrap.blogspot.com]
March 29, 2011 04:36AM
Once the design is finished i'll do a wiki entry including the eagle files to keep sebastien happy smiling smiley
Don't forget to wave it at reprap-dev at some point, since you're an official dev doing official dev it may be compulsory and so on.
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
March 29, 2011 09:34AM
richrap Wrote:
> Hi Andrew
I'm not sure it's worth the added cost. Running a 5v wire is simple since you are already running all the step/dir wires.
> of them.>
Will Do! I meant to do this in the beginning but forgot..
For what benefit? Most of the generic connectors for steppers are at .1" spacings, are they not?
> way.
I was holding off on the silkscreen until I knew which way to turn the pot myself winking smiley
I'm also thinking about adding pads for resistors as an additional alternative to the pot. Seems like the Pot is very fiddly to adjust, and I eventually want to pair these with a specific set of steppers.
Nope. Not yet at least. Worth some consideration though.
> have to try that.
I'll try and break out the REF. I'm running things on my end from a 328 so pins are at a premium. Maybe i'll have to give in and switch to the 6xx bandwagon.
I'll stick with 4 channel till i make some money back, I'll consider a separate board for channel 5 of maybe a 5ch board.
Unfortunately it's all done in free eagle so I'm pretty size limited.
> [lh5.googleusercontent.com]
> yQyeC-3I/AAAAAAAAAKs/bjr2ClOZTxQ/s400/RAMPS_PLUS_B
> just let me know.
> Good luck with it.
> Rich.
Thanks for the input!
March 30, 2011 01:06AM
I would suggest a test point for the REF voltage so that the voltage can be easily read with a voltmeter (at least, I could not identify one in the picture).
