Reprap Firmware on Due/RADDS SD Card September 05, 2017 03:09PM |
Re: Reprap Firmware on Due/RADDS SD Card September 06, 2017 02:56AM |
Re: Reprap Firmware on Due/RADDS SD Card September 06, 2017 04:03AM |
Re: Reprap Firmware on Due/RADDS SD Card September 06, 2017 10:20AM |
Re: Reprap Firmware on Due/RADDS SD Card September 18, 2017 07:46PM |
; Configuration file for The Imp ; Communication and general M111 S0 ; Debug off M550 Ptheimp ; Machine name and Netbios M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration M569 P0 S0 R1 ; Drive 0 goes forwards M569 P1 S0 R1 ; Drive 1 goes forwards M569 P2 S0 R1 ; Drive 2 goes forwards M569 P3 S0 R1 ; Drive 3 goes forwards M574 X2 Y2 Z2 S0 ; set endstop configuration M665 R174.35 L345.32 B152.00 H400.34 X-0.45 Y-0.03 Z0.00 M666 X0.18 Y0.64 Z-0.81 ; put your endstop adjustments here M92 X320 Y320 Z320 ; Set axis steps/mm M201 X3000 Y3000 Z3000 E1500 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z20000 E3900 ; Maximum speeds (mm/min) M566 X800 Y800 Z800 E800 ; Max instant speed changes mm/min M579 X0.9997 Y1.0006 Z0.9965 ; Cartesian axe correction ; Thermistors ;M305 P0 T100000 B3950 R4700 H0 L0 ; set the bed thermistor M305 P1 T100000 B3950 R4700 H0 L0 ; set the first nozzle ;M305 P2 T100000 B3950 R4700 H0 L0 ; set the second nozzle M570 S180 ; Hot end heat timer ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set standby temperatures ;If you have a dual-nozzle build, un-comment the next 2 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set standby temperatures M92 E627 ; Set extruder steps per mm ; Z probe and compensation definition ;M558 P3 X0 Y0 Z0 ;G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z-0.3 ; set minimum Z T0 ;Set Tool 0 by default
Re: Reprap Firmware on Due/RADDS SD Card November 20, 2017 04:28PM |
