Gen 7 electronics questions March 31, 2011 09:27PM |
Re: Gen 7 electronics questions March 31, 2011 10:57PM |
Re: Gen 7 electronics questions March 31, 2011 11:58PM |
Re: Gen 7 electronics questions April 01, 2011 03:09AM |
From my understanding gen 7 is just ramps on a single board with less components.
How many people are running the gen 7?
Are there any problems or quirks I should be aware of? stable firmware, etc?
Unless there's a place I can purchase a board, I'm planning on etching it myself.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Gen 7 electronics questions April 01, 2011 10:58AM |
Firmware is the same as for RAMPS (Teacup, FiveD), just a different pinout. Since last week there's even a bootloader made for 20 MHz, so there's no reason not to use this 25% speed increase.
If you research new sources for the electronic components, please add them to the tables in the Wiki. If you're lazy, I can send you kits
Re: Gen 7 electronics questions April 02, 2011 03:46AM |
Re: Gen 7 electronics questions April 02, 2011 04:26AM |
I just need the chip and a programmer to install (Is that the right term?) the bootloader, right?
So the programmer is for the bootloader, is the "USB to TTL cable or USB to TTL breakout board" to actually program the firmware/send files to the printer to be printed?
Re: Gen 7 electronics questions April 05, 2011 04:38AM |
Re: Gen 7 electronics questions April 05, 2011 02:53PM |
Re: Gen 7 electronics questions April 05, 2011 03:59PM |
Re: Gen 7 electronics questions April 05, 2011 08:37PM |
Re: Gen 7 electronics questions April 05, 2011 08:43PM |
Re: Gen 7 electronics questions April 06, 2011 04:11AM |
What are the requirements for replacement FET's.
Re: Gen 7 electronics questions April 06, 2011 04:19PM |
Re: Gen 7 electronics questions April 08, 2011 06:18PM |
Re: Gen 7 electronics questions April 09, 2011 06:04AM |
Have things changed since a couple weeks ago
that no fimwares use on/off heater controll? I have some TIP 120's I might use unless that is no longer an option.
Re: Gen 7 electronics questions April 11, 2011 11:19PM |
Re: Gen 7 electronics questions April 11, 2011 11:55PM |
