Possibility of replacing Andciv board for another
November 26, 2017 02:51PM
Greetings.
I have a Mingda Glitar 3 (china) 3D Printer, it has a large build volume of 300x200x360, however its been underperforming in proper printing. Before I declare it a waste of money, I would like to replace the board with another that are more used in the community. I attach pictures of the printer and board. Any help about the subject will be highly appreciated. Thanks in advance!
Also a link for the board:
[www.hxlstore.com]
open | download - received_10206048074625914.jpeg (83.9 KB)
open | download - 23755820_10214688920161652_2206253731006106880_n.jpg (83.5 KB)
Re: Possibility of replacing Andciv board for another
November 26, 2017 03:12PM
Can you tell us in what way the printer is under performing? The performance of your printer might be limited by any of the following:
1. Firmware - in which case, installing more up to date firmware (if available) would help, or replacing the electronics by any electronics for which up to date firmware is available.
2. Electronics - in which case replacing the controller by modern 32-bit electronics and firmware would help. Some of the 32-bit options also provide a web interface and web upload to the SD card.
3. Mechanics - in which case upgrading the electronics and firmware won't help.
Also important:
- does the printer use 12V or 24V power (or another voltage)?
- what model numbers are the stepper motors? They are usually labeled.
- does it have an LCD panel, if so what type is it?
November 26, 2017 09:13PM
I have Mingda 4c ,i,ANDCIV disappeared from market and no firmware available for board and display,,My board burn 2 time thermocoupler fuse and i replace with MKS Sbase Smothie and 3,2 TFT display,It require cutting bigger opening for TFT display and hole for external card reader, I replace Y Nema 23 stepper motor with Nema 17 and all stepper motors cable, Thermocouple is replaced by thermistor,Thermocoupler you can use if you add thermocoupler decoder to board ,
If you need ANDCIV board and color TFT display i have my laying in box for long time, ANDCIV board you can find on Taobao for 90 usd
[s.taobao.com]
Firmware for board / display and config file i post on forum [forums.reprap.org],
Review of board you can find on [www.nanjixiong.com]
Mingda use 24 V power supply
Thermocoupler K type
Stepper motors are Bohong Nema 17 0,85 A for X,Z and E Motor
Stepper motor for Y axes is Bohong Nema 23 1,6A
Pulleys and belts MXL
Edited 1 time(s). Last edit at 11/26/2017 09:22PM by edvard rahel.
