Galvo Laser Control Firmware
Posted by marinusdebeer
March 27, 2018 04:40PM
I am working on my capstone project for engineering. We are building a CNC Laser Engraver using Galvo mirrors. The problem we are having is finding firmware that can control the mirrors. I know GRBL is used for Gantry system lasers, but I don't think that will work appropriately for galvos. The purpose is to take in an image as input, convert it to some format (probably g-code) then send to Arduino to perform the particular engraving.
I dont know if the GRBL firmware can actually control the galvos if the g-code is just in the appropriate form for galvos, or if we have to find different firmware and different g-code to handle the operations.
Any help would be appreciated!
Marinus
VDX
Re: Galvo Laser Control Firmware
March 27, 2018 06:02PM
... I've used servo-motors instead of galvos to rotate the mirrors and a servo-driver, controlled by DIR+CLOCK, like a stepper motor.
Here's a video while moving and homing this "XY-servo-scanner" - [vimeo.com]
- and here showing it in action - [vimeo.com]
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
March 28, 2018 06:52AM
VDX
Why motors instead of galvo ? Heavy mirrors to move ? Need to cover a large area ? Accuracy ? Do you use high res encoders ?
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
VDX
March 28, 2018 07:09AM
... this was more for testing with heavy mirrors (size=45x40x5mm) and "common" CNC-software-combos winking smiley
And the servos had a pretty high accuracy with a gearing of 400:1 !!
Viktor
April 13, 2018 01:40AM
"Galvo" is only halve of the story - a galvo needs some control loop electronics which keeps the galvo at a defined position. This control loop is somethign which definitely has to be done in hardware, you can't control this with a weak Arduino. So the question is, what data do your galvo controllers expect?
