RADDS Cant Upgrade Repetier Firmware?
June 23, 2018 09:47PM
I have a 0.92.3 build of Repetier that has been working fine for ages, but recently got a probe, and wanted to upgrade to 1.0.2.
I left everything the same apart from the setting related to the probe, downloaded the firmware, unzipped and flashed, only to be greeted by the Choose language screen, then the home screen showing the wrong temps 7° (its should about 24°+) and if I try and home XY or Z it just hangs on Homing..... ***Please Wait*** and nothing happens.
Am I doing something incredibly wrong, or is there an issue with RADDS and 1.0.2 Repetier?
Even uploaded the config from my 0.92.3 and changed nothing, but got the same results.
Edit to add:
Here is a link to the working 0.92.3 and non-working 1.0.2 if anyone has the time to look....I'm stumped at this point, just flashed back to 0.92.3 till I can get some help on what I'm doing wrong [drive.google.com]
Edited 2 time(s). Last edit at 06/23/2018 10:59PM by peps1.
Re: RADDS Cant Upgrade Repetier Firmware?
June 24, 2018 05:06PM
SOLVED
LB
July 12, 2018 12:54PM
How did you solve it? What kind of probe did you hook up?
July 12, 2018 03:14PM
LB
Used a BLTouch sensor and this guide:
[youtu.be]
