TMC2130 drivers buzz but don't turn
Posted by Chuppster
June 28, 2018 12:31PM
Hello!
I am using Ramps 1.4 with the Discount Full Graphics Display and SD Card Reader and I have downloaded the latest bugfix version of Marlin (as of 6-27-18). I have done a 20v conversion on the stepper/hotend side of the RAMPS.
I set up my four TMC2130 stepper drivers according to wiring diagrams I found online. When I start up the board and use the "Move Axis" feature to trigger a stepper, the stepper motor just vibrates and doesn't apply any actual torque. It does the same thing in StealthChop mode and SpreadCycle Mode. Below is the TMC section of my Configuration_adv.h.
 * Enable this for SilentStepStick Trinamic TMC2130 SPI-configurable stepper drivers.
 * You'll also need the TMC2130Stepper Arduino library
 * (https://github.com/teemuatlut/TMC2130Stepper).
 * To use TMC2130 stepper drivers in SPI mode connect your SPI pins to
 * the hardware SPI interface on your board and define the required CS pins
 * in your `pins_MYBOARD.h` file. (e.g., RAMPS 1.4 uses AUX3 pins `X_CS_PIN 53`, `Y_CS_PIN 49`, etc.).
 * You may also use software SPI if you wish to use general purpose IO pins.
#define HAVE_TMC2130
#if ENABLED(HAVE_TMC2130)  // Choose your axes here. This is mandatory!
  #define X_IS_TMC2130
  //#define X2_IS_TMC2130
  #define Y_IS_TMC2130
  //#define Y2_IS_TMC2130
  #define Z_IS_TMC2130
  //#define Z2_IS_TMC2130
  #define E0_IS_TMC2130
  //#define E1_IS_TMC2130
  //#define E2_IS_TMC2130
  //#define E3_IS_TMC2130
  //#define E4_IS_TMC2130
#endif
 * Enable this for SilentStepStick Trinamic TMC2208 UART-configurable stepper drivers.
 * Connect #_SERIAL_TX_PIN to the driver side PDN_UART pin with a 1K resistor.
 * To use the reading capabilities, also connect #_SERIAL_RX_PIN
 * to PDN_UART without a resistor.
 * The drivers can also be used with hardware serial.
 * You'll also need the TMC2208Stepper Arduino library
 * (https://github.com/teemuatlut/TMC2208Stepper).
//#define HAVE_TMC2208
#if ENABLED(HAVE_TMC2208)  // Choose your axes here. This is mandatory!
  //#define X_IS_TMC2208
  //#define X2_IS_TMC2208
  //#define Y_IS_TMC2208
  //#define Y2_IS_TMC2208
  //#define Z_IS_TMC2208
  //#define Z2_IS_TMC2208
  //#define E0_IS_TMC2208
  //#define E1_IS_TMC2208
  //#define E2_IS_TMC2208
  //#define E3_IS_TMC2208
  //#define E4_IS_TMC2208
#endif
#if ENABLED(HAVE_TMC2130) || ENABLED(HAVE_TMC2208)
  #define R_SENSE           0.11  // R_sense resistor for SilentStepStick2130
  #define HOLD_MULTIPLIER    0.5  // Scales down the holding current from run current
  #define INTERPOLATE       true  // Interpolate X/Y/Z_MICROSTEPS to 256
  #define X_CURRENT          1200  // rms current in mA. Multiply by 1.41 for peak current.
  #define X_MICROSTEPS        16  // 0..256
  #define Y_CURRENT          1200
  #define Y_MICROSTEPS        16
  #define Z_CURRENT          1200
  #define Z_MICROSTEPS        16
  #define X2_CURRENT         800
  #define X2_MICROSTEPS       16
  #define Y2_CURRENT         800
  #define Y2_MICROSTEPS       16
  #define Z2_CURRENT         800
  #define Z2_MICROSTEPS       16
  #define E0_CURRENT         1200
  #define E0_MICROSTEPS       16
  #define E1_CURRENT         800
  #define E1_MICROSTEPS       16
  #define E2_CURRENT         800
  #define E2_MICROSTEPS       16
  #define E3_CURRENT         800
  #define E3_MICROSTEPS       16
  #define E4_CURRENT         800
  #define E4_MICROSTEPS       16
   * Use software SPI for TMC2130.
   * The default SW SPI pins are defined the respective pins files,
   * but you can override or define them here.
  //#define TMC_USE_SW_SPI
  //#define TMC_SW_MOSI       -1
  //#define TMC_SW_MISO       -1
  //#define TMC_SW_SCK        -1
   * Use Trinamic's ultra quiet stepping mode.
   * When disabled, Marlin will use spreadCycle stepping mode.
  //#define STEALTHCHOP
   * Monitor Trinamic TMC2130 and TMC2208 drivers for error conditions,
   * like overtemperature and short to ground. TMC2208 requires hardware serial.
   * In the case of overtemperature Marlin can decrease the driver current until error condition clears.
   * Other detected conditions can be used to stop the current print.
   * Relevant g-codes:
   * M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given.
   * M911 - Report stepper driver overtemperature pre-warn condition.
   * M912 - Clear stepper driver overtemperature pre-warn condition flag.
   * M122 S0/1 - Report driver parameters (Requires TMC_DEBUG)
  //#define MONITOR_DRIVER_STATUS
  #if ENABLED(MONITOR_DRIVER_STATUS)
    #define CURRENT_STEP_DOWN     50  // [mA]
    #define REPORT_CURRENT_CHANGE
    #define STOP_ON_ERROR
  #endif
   * The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD.
   * This mode allows for faster movements at the expense of higher noise levels.
   * STEALTHCHOP needs to be enabled.
   * M913 X/Y/Z/E to live tune the setting
  //#define HYBRID_THRESHOLD
  #define X_HYBRID_THRESHOLD     100  // [mm/s]
  #define X2_HYBRID_THRESHOLD    100
  #define Y_HYBRID_THRESHOLD     100
  #define Y2_HYBRID_THRESHOLD    100
  #define Z_HYBRID_THRESHOLD       3
  #define Z2_HYBRID_THRESHOLD      3
  #define E0_HYBRID_THRESHOLD     30
  #define E1_HYBRID_THRESHOLD     30
  #define E2_HYBRID_THRESHOLD     30
  #define E3_HYBRID_THRESHOLD     30
  #define E4_HYBRID_THRESHOLD     30
   * Use stallGuard2 to sense an obstacle and trigger an endstop.
   * You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin.
   * X, Y, and Z homing will always be done in spreadCycle mode.
   * X/Y/Z_HOMING_SENSITIVITY is used for tuning the trigger sensitivity.
   * Higher values make the system LESS sensitive.
   * Lower value make the system MORE sensitive.
   * Too low values can lead to false positives, while too high values will collide the axis without triggering.
   * It is advised to set X/Y/Z_HOME_BUMP_MM to 0.
   * M914 X/Y/Z to live tune the setting
  //#define SENSORLESS_HOMING // TMC2130 only
  #if ENABLED(SENSORLESS_HOMING)
    #define X_HOMING_SENSITIVITY  8
    #define Y_HOMING_SENSITIVITY  8
    #define Z_HOMING_SENSITIVITY  8
  #endif
   * Enable M122 debugging command for TMC stepper drivers.
   * M122 S0/1 will enable continous reporting.
  //#define TMC_DEBUG
   * M915 Z Axis Calibration
   * - Adjust Z stepper current,
   * - Drive the Z axis to its physical maximum, and
   * - Home Z to account for the lost steps.
   * Use M915 Snn to specify the current.
   * Use M925 Znn to add extra Z height to Z_MAX_POS.
  //#define TMC_Z_CALIBRATION
  #if ENABLED(TMC_Z_CALIBRATION)
    #define CALIBRATION_CURRENT 250
    #define CALIBRATION_EXTRA_HEIGHT 10
  #endif
   * You can set your own advanced settings by filling in predefined functions.
   * A list of available functions can be found on the library github page
   * [github.com]
   * [github.com]
   * Example:
   * #define TMC_ADV() { \
   *   stepperX.diag0_temp_prewarn(1); \
   *   stepperY.interpolate(0); \
  #define TMC_ADV() {  }
#endif // TMC2130 || TMC2208
