Hello,
I seem to be having a problem I feel like should be a pretty basic fix, but I am having a ton of trouble with it nonetheless. I am trying to upload my latest version of Marlin to my printer with some basic function changes, but I can't get the RUMBA to respond. The board is currently hooked up to my printer.
The errors I'm receiving are as follows:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
I realized I should just be able to whip the RUMBA into DFU mode by putting a jumper on the reset pins as explained on the RUMBA RepRap wiki page, but this did not work. I was told previously to fix this problem using an Arduino UNO as an ISP to reload the boot loader onto the RUMBA.
So I attempted to follow a tutorial online
here, using my Arduino Uno as an ISP for the RUMBA. This is how I connected the Arduino Uno to the RUMBA:
As the tutorial advised, I set the programmer to "Arduino as ISP" and then proceeded to "Burn Bootloader". I only had the Arduino connected to the computer, but the Arduino appeared to be supplying power to the RUMBA as well, as there were some lights flashing. Once I burned the boot loader, I assumed it had worked, as the Arduino software reported "Done burning boot loader", but I noticed during the process of uploading there were a series of errors that the Arduino software reported:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x18
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe6
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x18
I tried to upload firmware normally first, but received the same error I had to begin with. Next I tried to upload using the Arduino as ISP, and still had no luck. What can I do?
Thanks!
Sam
