Looking for a controller with native 5V pins for layer fans
Posted by ianmcmill
January 03, 2019 06:49AM
I can only find a 100$ Azteeg V3 with a 5V 2A controllable pin.
I used to have a RAMPS 1.4 + RRD Extender + Step-Down Converter soldered/screwed in place.
I want to go compact and less stacky-whacky with a decent price tag (20-40€)
Any ideas.
Blog: Capotexl
Filament Factory - How to build your own cheap filament extruder
Frankenstein Laser Engraver
Make the world a better place
Re: Looking for a controller with native 5V pins for layer fans
January 03, 2019 11:10AM
Duet WiFi, Duet Ethernet and Duet Maestro have the fan voltage selectable between VIN and 5V, but they are probably out of your price range too. With most controllers it is safe to connect the positive fan wire to a suitable +5V supply and the negative fan wire to the negative fan terminal on the controller.
January 03, 2019 11:14AM
So a PC power supply with a dedicated 5v rail would work.
Blog: Capotexl
January 11, 2019 03:26AM
I want to do almost the same as you only with the difference that my fan use 12V 0,23A. I just got them yesterday. I have already used the RRD extender for the 2 extruder fans.
I wonder if it is possible to use an Arduino 4way relay module (Which i have laying around for years) + external 12V power supply, and then connect it to some aux pins on the Ramps 1.4 ( I have Ramps 1,5) ?
Does anybody know ?
