Problem connecting board mks gen l
February 13, 2019 03:55AM
I need some help if possible..
When i connect my board to the pc this don't shows nothing..
When connect 2 lights turn on the corner one starts to blink then disappears the red stay on..
And 2 green lights stay on behind the usb shield but nothing happens..
Dead board??
Or can be fixed..
Thanks.
Here is a picture of board:
Re: Problem connecting board mks gen l
February 13, 2019 04:09AM
The image shows that it uses a standard ch340 usb/serial converter.
All the pc see is this chip.
it should turn up as s com/serial port.
you do need drivers... [sparks.gogo.co.nz]
If it is showing a com port.... there are other things to check....
You haven't said what your OS is, so cant give specific help.
Edited 2 time(s). Last edit at 02/13/2019 04:24AM by Dust.
February 13, 2019 04:23AM
Thanks...
I use Win 10 64Bits
Edited 1 time(s). Last edit at 02/13/2019 04:24AM by Lc1975.
February 13, 2019 04:25AM
So is a com port showing up when you plug it in?
what does device driver show?
February 13, 2019 04:29AM
Nothing...
I go to Device manager and no Port appears..
go to arduino and nothing to..
Use 3 different usb blue cables and nothing...
When connect a blue light and the red turns on.
Then the blue goes off only stays the red..
And both green light stays always on..
Edited 3 time(s). Last edit at 02/13/2019 04:38AM by Lc1975.
February 13, 2019 04:40AM
Those 2 green light have a (+) signal..
Maybe a short circuit??
February 13, 2019 04:46AM
check the ch340 has power? can you use a multi meter? Done any electronics?
pin 8 is gnd and pin 16 is vcc
pin 1 is marked with a dot on your image (U3)
check that pin 16 has voltage.
If it does have power the chip is likely dead.
February 13, 2019 04:48AM
ok.
going to see that
February 13, 2019 04:54AM
Yes has power..
4.40v in pin 1 and pin 16
Dead chip??
February 13, 2019 05:00AM
That would be my guess
I would try a different pc or two, just to make sure its not your OS messing with you.
Edited 1 time(s). Last edit at 02/13/2019 05:02AM by Dust.
February 13, 2019 05:02AM
Many thanks for your help...
Going to see if can find a a person here if can change that chip..
Many thanks..
smiling smiley
I used 2 different pc and is the same...
(No signal of the usb when connect and is the same with the lights..)
Edited 1 time(s). Last edit at 02/13/2019 05:33AM by Lc1975.
January 27, 2020 07:53PM
Hi, did you manage tu replace the CH340G chip on your MKS board? I think I fried mine when trying to connect a fan while the board was on
