is TB6560 can drive this motor?
Posted by okuzster
April 04, 2019 04:09AM
i posted it also under step motors but didn't get what i am looking for.
the motor is ELWOOD GETTYS M21-23E-6108CU
it says 1.4V and 3.8 amps for motor, if i get it right, driver would give it higher voltage and lower amper, can i adjust it?
Re: is TB6560 can drive this motor?
April 04, 2019 04:36AM
you normally run steppers at many times the voltage and up to the rated current
Lesser current will result in less torque, but it should move before then.
Depends how much torque you need for what ever your doing...
You can't adjust a steppers characteristics without rewiring it
VDX
April 04, 2019 05:34AM
... you'll need at least 2 Amps for proper functioning ... but it should move (slower and without much power) with only 1 Amp too.
What's the planned application?
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
April 04, 2019 07:34AM
TB6560 is 3 Amps if i am not wrong, so it should work.
a friend gave me it, who bought it to make a guitar pickup winder. so i can follow his way and try to make one.
he said it is broken, he couldn't make it run and was throwing it. but as i get it he didn't use any driver. not sure what he did, didn't ask for details. but motor itself can be damaged, i will see if it's running first.
VDX
April 04, 2019 08:57AM
... you can measure the resistance to identify the windings.
And a simple test is to move it by hand, shorten the respective windings and check, if the cunter-torque changes while turning ...
Viktor
April 04, 2019 10:59AM
i couldn't think about shortening the wires and check for counter torque, thanks!
motor is not with me now, will check it tomorrow.
