Pulling 24v from any pin on the Mini Rambo?
Posted by charlieRC
April 04, 2019 04:21PM
I have a bunch of 40mm 24v fans and I want to use one of them on a case that I just designed for the Mini Rambo. I know I can pull 24v from the input power (24v system) but would rather find a way to pull it from one of the board pins. There are two fan connectors, but I believe those are powered from a 5v rail (although the docs I"ve seen are not real clear). I've tried to find something that would better describe the board options, but I am not fining anything that will answer the question for me.
Re: Pulling 24v from any pin on the Mini Rambo?
April 04, 2019 09:56PM
The two fan outputs are at what ever voltage you apply to power B (fans, heaters, motors power plug)
April 05, 2019 11:58AM
Thank you!! That solves my problem.
