New replaceable stepper driver form-factor December 14, 2019 04:59PM |
Re: New replaceable stepper driver form-factor December 14, 2019 07:27PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: New replaceable stepper driver form-factor December 14, 2019 07:50PM |
Re: New replaceable stepper driver form-factor December 16, 2019 04:17AM |
Re: New replaceable stepper driver form-factor December 16, 2019 12:52PM |
Re: New replaceable stepper driver form-factor December 16, 2019 01:56PM |
frankvdh
Instead of mounting them on the controller board, is there any reason not to mount them on the stepper itself?
Re: New replaceable stepper driver form-factor December 16, 2019 10:32PM |
Mounting the drives on the steppers is possible, but complicates the wiring. Now you have to carry power + a reliable means of communication (like CAN). This in turn makes the driver expensive. If you are doing drivers with integrated encoders, it makes more sense. Like in dc42's example you cram a bunch of functionality into the board to justify the communication chip cost.Quote
frankvdh
Re: New replaceable stepper driver form-factor December 17, 2019 06:15AM |
Admin Registered: 11 years ago Posts: 3,096 |
ghent360
Greetings,
I've been designing my own controllers for about two years now. I really find the StepStick form factor to be limiting in two ways:
a) the board real estate is quite small and one has trouble fitting larger ICs like TMC2660 or TCM5161
b) the cooling on these is not great, because you have only one side exposed
On the other hand I have grown to appreciate the ability to quickly swap the drivers, when a new IC comes along with better features.
Here is a proposal:
Design a new form factor using PCIe 1x slot as base. The drivers would stack vertically which would provide cooling on both sides. Can have a bit more latitude with respect to the driver board size (my current experiment is around 40x40mm). PCIe 1x has 36 pins, which allows for more interesting things like automatic chain ID assignment.
Here are some pictures of my experimental design:
Google photos shared album
For reference this is a link to the board and driver schematics.
GitHub.com
Thoughts?
Re: New replaceable stepper driver form-factor December 17, 2019 11:36PM |
Re: New replaceable stepper driver form-factor December 18, 2019 03:59AM |
Re: New replaceable stepper driver form-factor December 18, 2019 04:29AM |
Re: New replaceable stepper driver form-factor December 18, 2019 04:34AM |
Re: New replaceable stepper driver form-factor December 18, 2019 07:15PM |
Re: New replaceable stepper driver form-factor December 19, 2019 04:30AM |
Re: New replaceable stepper driver form-factor January 03, 2020 12:58PM |
Re: New replaceable stepper driver form-factor January 03, 2020 01:08PM |
newbob
@dc42 are the 1uF that you recommend for VSA and VSB? I have not seen those on trinamic 2660 schematics but do see them (although 100nF) on tmc2130 which is from the same family as tmc5160.
Re: New replaceable stepper driver form-factor January 03, 2020 01:30PM |
Re: New replaceable stepper driver form-factor January 03, 2020 11:00PM |
Re: New replaceable stepper driver form-factor January 04, 2020 07:42PM |
Re: New replaceable stepper driver form-factor January 06, 2020 12:05AM |
Re: New replaceable stepper driver form-factor January 06, 2020 01:13PM |
Re: New replaceable stepper driver form-factor March 01, 2020 09:28PM |
Re: New replaceable stepper driver form-factor March 03, 2020 01:56PM |
Re: New replaceable stepper driver form-factor March 06, 2020 10:35PM |
Re: New replaceable stepper driver form-factor March 07, 2020 02:48AM |
Re: New replaceable stepper driver form-factor March 22, 2020 11:21PM |
