Issue with y motor on SKR v1.3 December 19, 2019 04:07PM |
Re: Issue with y motor on SKR v1.3 December 19, 2019 04:48PM |
Re: Issue with y motor on SKR v1.3 December 19, 2019 05:17PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Issue with y motor on SKR v1.3 December 19, 2019 05:52PM |
do you know how I could check that?Quote
Ohmarinus
Could the issue be between the driver and the connector on the board?
I do not see anything on the board, that is newQuote
Ohmarinus
Maybe a trace got damaged?
the drivers that I tested in that place worked on other position (x, z2, e) so that is not the problemQuote
Ohmarinus
Can there be an output pin on the driver that doesn't connect into the socket well? Etc.
