SKR 1.3 PC Recognize issue January 01, 2020 04:58PM |
Re: SKR 1.3 PC Recognize issue January 01, 2020 09:29PM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: SKR 1.3 PC Recognize issue January 02, 2020 08:27PM |
Re: SKR 1.3 PC Recognize issue January 04, 2020 08:09AM |
Re: SKR 1.3 PC Recognize issue January 04, 2020 08:13AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: SKR 1.3 PC Recognize issue January 04, 2020 08:22AM |
Ohmarinus
Can it be the jumper pin isn't installed on 'int' power setting? It's in the middle of the board where you can choose to either power it through USB or INTernal 12v?
I'm not sure what else could be the problem, this is where I would look first.
Re: SKR 1.3 PC Recognize issue January 04, 2020 08:25AM |
Re: SKR 1.3 PC Recognize issue January 04, 2020 09:06AM |
Dust
All you can do is re upload the firmware, ensuring the serial port is set to -1 in the firmware configuration (usb port) If that doesn't help, there is nothing you can do.
The usb is connected directly to the controller microprocessor. If it is not talking, the board is dead.
Re: SKR 1.3 PC Recognize issue January 04, 2020 09:43AM |
Re: SKR 1.3 PC Recognize issue January 04, 2020 12:40PM |
