Breaking Connections on Stripboard without Dremel?
June 12, 2011 08:34AM
What's the best way to break teh connections on stripboard "manually"?
Re: Breaking Connections on Stripboard without Dremel?
June 12, 2011 09:57AM
Use the tip of a drill with a diameter just bigger than the track width and twist it with your fingers.
Edited 1 time(s). Last edit at 06/12/2011 09:58AM by nophead.
June 12, 2011 12:27PM
You can also get fancy tools, which is basically a drill with a handle. [shop.ebay.com]
I made my own by drilling through a dome nut, soldering the drill bit in place, and adding connector nuts as a handle. Works great if you have trouble gripping the drill bit by hand. Thinking about it, there is probably a 3d printable design out there somewhere.
-Nudel
Blog with RepRap Comic
June 12, 2011 01:25PM
The best tool for the job is one of these: -
I don't know what it is called. It is a watchmakes tool I inherited from my dad.
Edited 2 time(s). Last edit at 06/12/2011 01:29PM by nophead.
open | download - tool.JPG (46.4 KB)
June 12, 2011 01:36PM
Any sharp knife will do. Do two close cuts, about 0.5 mm apart, and you can scratch off the small stripe in between.
June 12, 2011 02:38PM
Thanks grinning smiley
