FIXED - MKS Sbase 1.3 part cooling fans
Posted by Mils24
March 29, 2020 02:58PM
Hello All,
I’ve tried searching the forums and endless googling and I’m still stuck, so I’ve resorted to this for help.
In short - I don’t know how to add software (slicer) controlled part cooling fans on my MKS SBASE 1.3 board running Marlin 2.0.5.2.
I’ve a homemade delta with dual part cooling fans on the end effector. I have my fans connected to P2_06 E1 Heater and also FAN_AUTO_ON set to HEATER_PIN_1 (P2_06) in Config_adv.h in marlin.
The problem is that the fans come on full when hotend is 50°> and can’t be controlled through pronterface or the screen (MKS TFT32)
Surely there is a way to control these fans so that I can leave them off for the first few layers and then bring them on? Or reduce them to 30-40% when printing ABS?
What am I doing wrong??
Edit - title changed to 'FIXED'
Edited 1 time(s). Last edit at 03/30/2020 05:18AM by Mils24.
Re: Problem - MKS Sbase 1.3 part cooling fans
March 29, 2020 11:09PM
FAN_AUTO_ON is for the hotend heat break fan not part cooling. Also you must be running a really old marlin, as current version wont even let you try this bad combination.
It does as you say, it turns on > 50c. There is no software control of this fan.
The FAN_PIN is the one that is software controllable. Since you insist on wiring to a non standard place you need to add a #define FAN_PIN P2_06 to you Configuration.h
Edited 3 time(s). Last edit at 03/29/2020 11:30PM by Dust.
March 30, 2020 05:17AM
Cheers Dust, you have just made me remember my vital flaw!! Problem now fixed.
What happened - I had originally used FAN_PIN for connecting the part cooling fans but could not get them to work/spin. This is why I then moved to the HEATER_1_PIN in the hope that it would work however they didn't initially. Therefore I swapped my two JST pins around realising that the polarity of the pins must of been wrong. This was correct and as a result the fans spin.
What I failed to do, was to then remember to move the fan connections back to FAN_PIN...... Duh!
Job done now and all working as it should do.
