Archim2 board - Analog input for PT100 + amplifier board thermistor May 26, 2020 01:02PM |
Re: Archim2 board - Analog input for PT100 + amplifier board thermistor September 15, 2020 09:48PM |
I’m also curious about thisQuote
JohnLovaasen
I have a TAZ Pro printer that I'm upgrading to print higher temperature materials. I have the PT100 + amplifier board from E3D. I've used this setup previously on a TAZ 6 with a RAMBo board where I plugged the signal wire into an extra analog input pin and changed the pin assignments. Now that the TAZ Pro uses an Archim2.2b board, I'm having a problem finding an open analog input pin from the schematics. Do you know if this is possible to use the PT100 + amplifier board from E3D on the Archim2 boards or if there is a different thermistor that I can plug directly into the thermistor inputs? I'm looking to go up to at least 450C. Thanks.
Re: Archim2 board - Analog input for PT100 + amplifier board thermistor September 16, 2020 02:53AM |
Admin Registered: 11 years ago Posts: 3,096 |
rorypettit
JohnLovaasen
Re: Archim2 board - Analog input for PT100 + amplifier board thermistor September 16, 2020 09:59AM |
