Hi all,
I'm facing an issue of which I do not have sufficient knowledge. The SKR1.4 is driving the old Replicator wonderfully but when the bed is heating, there's a high pitched sound coming from the electronics board.
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current in Marlin. I am afraid to lower it because I understand this will put strain on the MOSFET.
Should I check the bed's resistance? I did and it is
4,7Ohms Should I build a circuit with a power mosfet to drive the bed power? Should I limit the current through the firmware? (Marlin).
It's a 24v system. I've never heard this noise and don't know if it's good or not.
Update:
I did some more research and found this:
github.com]
It says:
According to this website:
ohmslawcalculator.com]
A heated bed with 24v and 4,7Ohms of resistance should pull this:
So, if the SKR 1.4 can deliver 144W to a bed with higher than 1Ohm resistance, and according to the formula my bed pulls 122W and has 4,7Ohms, that should be safe right?
So, I'm wondering, where could the high-pitched wine be coming from? And is there maybe a way to limit the current draw of the bed through Marlin by using a lower PWM signal or some tech?
Edited 4 time(s). Last edit at 07/31/2020 05:54PM by Ohmarinus.
http://www.marinusdebeer.nl/
