RepRap for carving?
September 23, 2009 12:14PM
I tried doing some searching but had no luck.
Has anyone explored using a RepRap to carve things instead of print things? I am thinking that it could be useful to carve signs or templates, mostly 2d structures, in addition to printing 3d structures. I would think that added flexibility would make RepRaps a much more desirable tool for the masses.
So maybe I missed it, but could you replace the extruder head with a Dremel tool for example?
Thanks,
Joe H.
Re: RepRap for carving?
September 23, 2009 01:02PM
What you're describing sounds like a normal CNC machine and there's already a ton of plans/sites for making your own.
Only thing that maybe could improve on that idea is to design a Dremel holding that can tilt to carve at odd angles, personally I haven't seen that for the home built machines.
September 23, 2009 02:20PM
Maybe we could use a Dremel to drill holes and smooth the object after printing.
September 23, 2009 02:22PM
A cartesian robot is not suited for carving, for that you are likely to need a 5 axis CNC or a robot arm
The robot arm is a good proposition but it would need to sit on a turntable or the the work to be on a turntable to access areas to carve
September 23, 2009 07:08PM
I've got a plan to use a reprap to build the parts for a robotic arm like that, but smaller of course. It'll allow for more complex shapes, different kinds of fabrication (like friction welding), and in general really shake things up.
Now if only programming arms wasn't so complex...
September 28, 2009 01:54AM
You could do simple 3d subtractive carving if you stick a router or router-equivalent toolhead on the reprap.
My little central coast thing is working on that. But, of course, it'll take a while. You could also just stick a really strong dremel in there, turn it on, and start carving. I'd imagine you could make a model like now, but reverse it (stick model and subtract it from a digital brick).
