Would I be able to use the Mendle Electronics to control it? I ask because If I can I will probably make it so I can use one set of electronics with both my Mendel and the milling machine. If so what modificatons would have to be made (If any)?
Hi Just browsing the forums.... I am buying a CNC machine... and I plan on starting a Mendel Reprap soon after my CNC arrives... I am wondering...if I replace the router on the CNC... with an Extruder set up from reprap... will this work for 3D printing? Would I use the same software...ir Rhino 3D / TurboCAm/ Sketch up?... or is diffrent software needed?.. ( i'm thinking diffrent software..when I imagine the process ).. Any helpor advice you can give is much appreciated. rockislandstudio@gmail.com
