Problem with x axis caliberation May 07, 2018 10:17PM |
Re: Problem with x axis caliberation May 08, 2018 02:34AM |
Re: Problem with x axis caliberation May 08, 2018 06:49AM |
I used auto caliberation on the y (also with belt and pulley) and on the z axis (lead screw) and got accurate resultsQuote
o_lampe
Do you have to use the autocalibration? What were the results of calibration? Less or more steps/mm?
Did you try to hardcode the 40steps/mm?
How smooth does the X-axis run? Do you feel any binding?
Re: Problem with x axis caliberation May 09, 2018 02:52AM |
