Low cost CNC mill/repstrap from old printers & scanners parts
Posted by Petrus
Re: Low cost CNC mill/repstrap from old printers & scanners parts
January 19, 2013 03:18PM
It's a chuck from a noname dremel-like flexible shaft
February 18, 2015 11:51AM
Testing one axis (with a gcode file ) on an Epson Stylus 600 Mainboard (stepper motor driver is the chip A2917). I'm using an Attiny2313 as translator between the Arduino Uno (pre burned with grbl interpreter) and the A2917 driver. A rusian coder is the author of the translator .hex file ( DOWNLOAD ): WATCH MY TEST VIDEO
Edited 1 time(s). Last edit at 02/18/2015 11:52AM by zandunga.
March 19, 2015 07:19AM
what software did you use to convert the pcb output file to stl file? how did you get pu and pd commands to turn into G1 x y z comands lines?
very nice job you did
Hi, I use EM - 257 engines .
I use the original belt MG5778 . You know what is the exact step of this belt ?
someone who has no precise information on this belt ??
January 07, 2016 04:02AM
Can't see the small red text, but looks like an S2M belt.
Edited 1 time(s). Last edit at 01/07/2016 04:03AM by Kenzu.
Kenzu
Hi Kenzu,
I have two belts.
The first belt was removed from epson stylus color 480.
The second belt was removed from epson stylus color 680.
Both straps are marked with MG5778.
The belt taken from epson480 is marked in red: C9KD - 26089 - 516
The belt taken from epson680 is marked in red: E9KD - 01093 - 605
I don't know S2M.
Belts S2M that step have?
hi,
have you read what I wrote before ?
I measured the number of teeth on a piece of belt 130mm long .
( unfortunately my caliber is small and I could measure the entire belt)
There are 62 teeth on 130mm .
So there are 61 pitch .
The tooth thickness measured with the caliber is about 0,95mm .
Now the pitch of my belt appears to be about 2,1155mm .
But this value is not accurate .
We can go back through these parameters to the type of belt ?
HELP ME!!!!!
hot smileysmiling bouncing smileyhot smileysmiling bouncing smileyhot smileysmileys with beersmileys with beer
Sorry printers are epson stylus color 440 and 460
this is:
