V1 Engineering's Piper April 29, 2019 11:32AM |
Re: V1 Engineering's Piper April 29, 2019 11:58AM |
Re: V1 Engineering's Piper April 29, 2019 12:33PM |
Re: V1 Engineering's Piper April 29, 2019 01:16PM |
Robert, You have mixed up a little with names . Ryan's MPCNC is at www.v1engineering.com.Quote
Roberts_Clif
I have decided to build the V1 Engineering Piper.
First C-Foot 3D Print in ABS looks promising, with ABS shrinkage the ID for the Feet is 23.37 the conduit measurement is 23.5.
This means that very little finish work will need to be done in order to assemble the Piper 3D Printer.
Re: V1 Engineering's Piper April 29, 2019 02:05PM |
piper3d
My Piper 3d Printer is at https://piper3dprinters.com/
Shank man
Why not use PETG?
Just a thought.
the_digital_dentist
I usually run 240C first layer, then 235 for the rest of the print. Prusa defaults to 255C throughout a print.
Don't use a print cooling fan on ABS. It will make prints pull themselves apart.
Re: V1 Engineering's Piper April 29, 2019 02:09PM |
Re: V1 Engineering's Piper April 29, 2019 02:37PM |
the_digital_dentist
Most printers can't print ABS because they aren't made to do it.
If you can print ABS, there's little reason to print anything else...
Re: V1 Engineering's Piper April 29, 2019 03:27PM |
Re: V1 Engineering's Piper April 29, 2019 03:40PM |
You may want to look at "FilaDry" device. It promises to dry filament as it moves it from the spool to the extruder. It was shown at MRRF and it was feeding the filament from the spool drawn in the aquarium tank full of water to the extruder.Quote
the_digital_dentist
The biggest problem I found was that it sucks moisture out of the air.
Re: V1 Engineering's Piper April 29, 2019 05:12PM |
Re: V1 Engineering's Piper April 29, 2019 07:50PM |
the_digital_dentist
228C is a bit low for ABS. I usually run 240C first layer, then 235 for the rest of the print. Prusa defaults to 255C throughout a print.
Don't use a print cooling fan on ABS. It will make prints pull themselves apart. You got away with it because it was a small print.
Re: V1 Engineering's Piper April 30, 2019 05:44AM |
Re: V1 Engineering's Piper April 30, 2019 09:51AM |
Re: V1 Engineering's Piper April 30, 2019 11:03AM |
Roberts_Clif
The foreseeable problems include finding the smoothest EMT conduit possible, have never thought about smooth conduit before.
Keeping the weight down of the hardware may not be a problem with dual XY steppers, though may come into consideration for other reasons...
Re: V1 Engineering's Piper April 30, 2019 08:28PM |
obelisk79
I had previously considered doing one of these builds. There is always the option of buying stainless steel tubing. The website lists the cost of stainless for a standard MPCNC build to be approx $43USD.
Re: V1 Engineering's Piper May 05, 2019 08:26PM |
Re: V1 Engineering's Piper May 06, 2019 03:47PM |
Re: V1 Engineering's Piper May 07, 2019 08:07AM |
Re: V1 Engineering's Piper May 07, 2019 12:10PM |
Re: V1 Engineering's Piper May 07, 2019 01:42PM |
Re: V1 Engineering's Piper May 08, 2019 05:06AM |
Re: V1 Engineering's Piper May 08, 2019 09:31AM |
Shank man
Irregardless those are some damn nice prints. I really need to make some enclosures for my printers.
Pippy
Yes interesting.
You'll have to show us the whole printer in your next video.
What printer controller board & stepper drivers are you using I wonder ?
Re: V1 Engineering's Piper May 08, 2019 10:42PM |
Re: V1 Engineering's Piper May 10, 2019 05:23AM |
Re: V1 Engineering's Piper May 12, 2019 05:06PM |
Re: V1 Engineering's Piper May 12, 2019 06:41PM |
piper3d
the_digital_dentist
Re: V1 Engineering's Piper May 12, 2019 08:42PM |
Pippy
piper3d
the_digital_dentist
I'd maybe not ..
FilaDry test
Re: V1 Engineering's Piper May 14, 2019 11:03PM |
Re: V1 Engineering's Piper May 15, 2019 02:21AM |
Re: V1 Engineering's Piper May 16, 2019 11:14PM |
