Re: V1 Engineering's Piper May 27, 2019 12:24PM |
Re: V1 Engineering's Piper May 27, 2019 01:38PM |
Ernest1122
Makers here bought a fruit/vegetable/herb/meat dryer and the size just matches. XDD
[www.aliexpress.com]
or dry cabinet for DSLR for long term purpose.
Re: V1 Engineering's Piper May 27, 2019 01:40PM |
Shank man
Irregardless those are some damn nice prints. I really need to make some enclosures for my printers.
Re: V1 Engineering's Piper June 01, 2019 11:11AM |
Re: V1 Engineering's Piper June 06, 2019 09:47PM |
Re: V1 Engineering's Piper June 07, 2019 08:06PM |
Re: V1 Engineering's Piper June 08, 2019 04:09AM |
Admin Registered: 12 years ago Posts: 3,096 |
Roberts_Clif
Today I received the five steppers, and setup a Ramps controller test, decided to start with a V-Ref of .450
Setup all steppers an preformed simple moves on X, Y, Z, X2 an Y2 drivers functioning at my test current..
Re: V1 Engineering's Piper June 08, 2019 09:13AM |
Ohmarinus
A piece of advice; setting vref with a meter only gives you an indication.
Re: V1 Engineering's Piper June 08, 2019 09:28AM |
Re: V1 Engineering's Piper June 08, 2019 01:29PM |
MKSA
Considering all these bearings pressing and trying to roll on two galvanized steel tubes (what about their alignment ?), no wonder you need a lot of torque !
Re: V1 Engineering's Piper June 10, 2019 02:52AM |
Re: V1 Engineering's Piper June 20, 2019 11:53PM |
Pippy
That's a nice PSU you're made, you've done a great job Roberts_Clif !
Looking at your circuit diagram (which is very nice by the way), we generally go by a rough rule of thumb in the development department of 2200uf per amp for the smoothing caps and add plenty of HF decoupling/filtering too when designing new PSU's, but that's for high-spec PSU's for industrial and school use etc.
Re: V1 Engineering's Piper June 24, 2019 01:08PM |
Re: V1 Engineering's Piper June 24, 2019 01:25PM |
Re: V1 Engineering's Piper June 24, 2019 03:44PM |
the_digital_dentist
If you're going for professional results, why do you keep messing with toy electronics? Those failing/failed motor driver modules are trying to tell you something. Get a Smoothie-board or a Duet (not a junky clone from China) and be done with it.
Re: V1 Engineering's Piper June 24, 2019 04:49PM |
Re: V1 Engineering's Piper June 24, 2019 06:14PM |
Re: V1 Engineering's Piper June 24, 2019 07:42PM |
Shank man
Are you going to use end stops and implement the auto squaring function?
Shank man
What software are you going to use to make the G-code?
Re: V1 Engineering's Piper June 25, 2019 12:25PM |
Re: V1 Engineering's Piper June 26, 2019 06:37AM |
Re: V1 Engineering's Piper June 26, 2019 07:18AM |
Shank man
Have you decided on a spindle yet? Will it be switched on/off through the software? I was thinking of powering a relay through the fan connector on the RAMPS board to control the power to the spindle motor. What do you think?
Re: V1 Engineering's Piper June 26, 2019 09:48AM |
Shank man
Ohmarinus
I'm not sure of that's a good idea. Would you be able to use PWM for the spindle speed that way?
Re: V1 Engineering's Piper June 26, 2019 12:40PM |
Ohmarinus
Shank man
Re: V1 Engineering's Piper June 26, 2019 02:02PM |
Re: V1 Engineering's Piper June 27, 2019 06:12PM |
Re: V1 Engineering's Piper June 29, 2019 06:55PM |
Re: V1 Engineering's Piper July 02, 2019 01:08PM |
Re: V1 Engineering's Piper July 03, 2019 12:21PM |
Re: V1 Engineering's Piper July 08, 2019 11:19AM |
Re: V1 Engineering's Piper July 08, 2019 05:07PM |
Roberts_Clif
I have noted a distinctive difference between the SD card Print and the OctoLapse Print textures.
Noted: in the Photos above the model on right was printed with the SD Card While Model on the left within OctoPrint's Octolapse.
You will note a distinct texture difference. Will print another model using same ABS filament with SD card to verify if smoothness returns.
. I am hoping to be able to print directly to a Duet from Simplify3D and CURA.
