Pick-and-Place November 29, 2009 03:30AM |
Admin Registered: 17 years ago Posts: 1,791 |
Re: Pick-and-Place December 03, 2009 09:44AM |
Re: Pick-and-Place April 09, 2010 07:58AM |
Re: Pick-and-Place April 09, 2010 03:59PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Pick-and-Place April 20, 2010 08:14AM |
Re: Pick-and-Place April 20, 2010 09:22AM |
Re: Pick-and-Place March 06, 2014 04:35AM |
VDX
... Some of the prototypes are available - if you need something special, i can reactivate or rebuild most of them ...
Re: Pick-and-Place March 06, 2014 12:47PM |
Re: Pick-and-Place March 06, 2014 01:19PM |
VDX
... Can pack then my car with some of the tools and equipment for p&p and microassembly/microinspection from my basement ...
Re: Pick-and-Place May 31, 2014 08:33PM |
Might there be an easier way to add components (e.g. computer chips) to a circuit board? Dispense the computer chip on the circuit board. Also dispense a small magnet on the circuit board. The small magnet can be moved around by moving another magnet underneath the circuit board.
Using a video camera, an artificial-intelligence may locate the chip, and push the chip to it's correct location with the small magnet.
Once everything is in place, we can keep spraying the circuit board with glue until everything sinks in.
Note:
Maybe the small magnet should have low friction, because it presses against the circuit board and you don't want it to scratch the circuit board too much.
The dispensing mechanism does not need to be perfect... If we dispense too many unneeded components, we can move them out of the way. But what if a component becomes upside-down? The small magnet can have wedge or something to flip components. Or it can push the upside-down component out of the way and use a component that is not upside-down.
Will it work?
Re: Pick-and-Place May 31, 2014 09:01PM |
Re: Pick-and-Place June 01, 2014 10:34AM |
Re: Pick-and-Place June 02, 2014 11:48PM |
Ant
Chips are not magnetic. Anyway, the way they do it now is fairly easy to do and all figured out.
Re: Pick-and-Place June 04, 2014 10:12PM |
Re: Pick-and-Place June 09, 2014 11:21PM |
Re: Pick-and-Place January 21, 2015 06:50PM |
