1W blue laser on prusa
Posted by wen li
April 25, 2012 04:14PM
Dear all,
we managed to run a 1W laser directly without modified electronics. The laser now is a hot swappable toolhead for more flexible repraps and a better future.
Check out our blog post and video!
Greetings,
Wen Li
Re: 1W blue laser on prusa
May 31, 2012 04:33AM
Nice one - what laser are you using? I bought a wickedlasers Arctic Spyder (1W blue) a while ago, but it's too heavy and too huge. Mabye I will disassemble it?
Or do you have a source for the laser diode and driver?
Well done!
June 04, 2012 06:40AM
Hi smiling smiley I'm acutally building my own laser adapter for my prusa, I bought these
[cgi.ebay.fr]
The laser, featuring a glass lens to get good focus and high power.
And this laser driver
[cgi.ebay.fr]
Who gets up to 2A, it's more than sufficiant for the Laser Diode who accepts a maximum of 1.7/1.8A, driver is protected by a potentiometer.
Hope it will help smiling smiley maybe posting some pics when i'm done smiling smiley
Cya
VDX
June 04, 2012 02:59PM
... are you sure, the diode can survive this currents for more than some ten hours?
AFAIK there are only 1W-diodes with 445nm out there, but some vendors specify them for 1.5Watts or even more, what's only possible for short time and with heavy cooling (TEC's or water-coolers)
Viktor
June 04, 2012 03:39PM
I'll take car of not going to more than 1W i think,
and i planned to put an heavy heatsink with big fan on it !!!
Atfer that seing the lifetime at this power ...
But bigger is specified, and running lower is better for lifetime I suppose.
On RepStrap
December 21, 2012 12:31PM
[www.youtube.com]
smoking smiley
Next I try to find out, which materials/speeds are suitable for cutting.
Edited 1 time(s). Last edit at 12/21/2012 12:40PM by Tertzoid.
January 04, 2013 03:03PM
Well M140 diodes from this guy with the small marking on their barcode
can be driven up to 1400mA with no real problems apparently smiling smiley
Im going to use a 4 AMC7135 led driver for that purpose (1400mA) with a heatsink
September 04, 2013 05:39PM
I have been selling a 1.7W 445nm Diode Laser head that works in conjunction with the 3D extruder with no need to swap out for laser cutting. We have a Makerbot 3D printer that we use for laser cutting solder stencils and other things. We have sold upgrade kits to people with RepRap and Felix printers as well.
Check out: www.laser-bot.com for more details.
Or check out www.jtechphotonics.com to buy the kit. 1.7W laser kit with adjustable 2.0 amp driver is only $224.99.
Jay
October 06, 2013 06:52PM
nice driver and even more nicer tests with the balsa. I would believe 1/8balsa can be cut so nicely.
but I would consider your driver a little bit overengineered . Lasers are diodes as LEDs. And because of a big interest in LED drivers, you get all kind of nice current limiting sources for quite cheap.
for example AMC7135 chip gives 350mA and can be parralled meaning 4 in a row give you 1.4A (your supply voltage should not exceed 6V though, the 5V input of the regular ATX power supply is fine)
pt4115 can be driven up to 1.25A and can be adjusted with a simple potentiometer and can be supplied with more than 30V input.
and all these cost not more than 2-3 euros to make
October 08, 2013 07:27PM
Thanks! I am going to try and cut birch plywood and ABS plastic next. It really does a pretty nice job of cutting things that just a few years ago it wouldn't with the 1W lasers.
I would agree that the driver might be a bit over engineered for most folks doing hobby lasers. I sell this to research labs and industry and they really need the 0.001 resolution and holding accuracy, which is not really needed for this application.
To drive these lasers you need more than 1.25amps, you will need at least 1.7amps for the 1.7W and we are coming out with a 2.6W that needs 2.2amps. It gets a bit tricky when you get to sourcing 2 amps or more, especially dealing with the thermal issues.
It uses three 1.1amp regulators in parallel to dissipate the heat generated from the voltage drop and current sourcing. I tried using real cheap LM317 variants in the beginning, but they would thermal shutdown in just 20 seconds of near full current draw. I then went to a larger LT1083 design (7.5amps) and it still only gave about 40 seconds of on time before thermal shutdown. Putting normal regulators in parallel can be tricky to get them balanced. You might not need the isolated input, but then again you know you are not going to blow up the driver by plugging in a 24V relay switch to it from an old CNC computer. Anyway, you can get cheaper drivers out there for sure, especially if you look towards the LED market instead. You might just be having some trade-offs for performance and features. smiling smiley
VDX
October 09, 2013 02:58AM
... my first (and most reliable) drivers with currents up to 5Amps (5x LM317) or 9Amps (2xLM317+3xLM338) use parallel LM317 (for 1Amp each) or LM338 (until 3Amps each) without any issues - I'm selecting the max. current with jumpers to sum the needed count of LM's and then switch the current through the LM's to the diode with a MOSFET ...
Viktor
October 09, 2013 04:19PM
@jtechphotonics birch plywood would be an awesome test. you encourage me to finally finish my laser cutter (based on a 2D mendel90) which is muddling for the last 3-4 months.
I wont argue about the needed resolution and accuracy, for some people its essential. But allow me to disagree on the laser drivers. While PT4115 is limited to 1.25A, AMC7135 are designed to work in parallel.
So by using jumpers (my cheap solution) or a microcontroler you can set your current pretty accurately to 350mA increments. Drivers with 8 AMC7135 and selectable power outputs are available for LED flashlights and that means 2.8A, for around 5USD . AMC7135 wont complain as long as you feed it with less than 6V (5V would be definitely better). And the simplicity of the circuit is such, that nearly nothing can go wrong for you. The AMC7135 is a driver on a chip solution no external components needed.
Im sure you can scale this up even more with no heat issues as every AMC7135 chip will only provide 350mA so heat is distributed among the chips. have a look and why not a try. You can find AMC7135 chips quite cheaply for your tests.
October 09, 2013 06:26PM
@waste. I checked out the AMC7135 and it does look like a very simple and nice solution. I will get some and try it out for a cheaper driver. I guess my holdup has always been the desire to have a fully adjustable current source. I like to test my lasers when they get in and make a current versus watts graph in 50ma increments. The downside is on these they are only in 350ma increments, but for 1/10th the price it will be worth it. Thanks for the info! smiling smiley
Just tried cutting ABS and boy what a mess. I need to get a air assist going to keep the fumes down... Cut through 1/16 inch though after 4 passes. The trick is not getting it to catch fire. It definitely needs some tweaking. I think the birch is a better idea for the next test.
October 11, 2013 01:23PM
ABS has nasty fumes hasnt it? but if we want any material not to catch fire why dont we use a fan blowing where the laser burns? if the air flow is high enough, you will extinguish any fire smiling smiley
the problem is that if the air flow is too small you will make any fire worse lol lol smiling smiley
October 11, 2013 04:37PM
There is a small 5V fan output on my driver board, so I hooked it up and printed out a holder to connect it to the XY table and it seemed to do the trick. No more fire, but the fumes are still horrible. What I really need is to close up the printer/laser and put a vacuum on one side with a filter in the path and exhaust it outside.
No more fires though which is a good thing! smiling smiley
