Information needed before buying what I need December 17, 2014 07:30AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Information needed before buying what I need December 17, 2014 08:23AM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Information needed before buying what I need December 17, 2014 09:57AM |
Re: Information needed before buying what I need December 17, 2014 10:25AM |
Re: Information needed before buying what I need December 17, 2014 02:35PM |
Re: Information needed before buying what I need December 20, 2014 09:38AM |
The diode should not be powered when its temperature is over 30C? If the ambient temperature is around 24C, you would only have 6C left until shutdown.Quote
VDX
... and the NTC/thermal protection is to shut down the driver, when the diode starts overheating (>30degC)
Re: Information needed before buying what I need December 20, 2014 07:16PM |
Re: Information needed before buying what I need December 21, 2014 04:10AM |
Re: Information needed before buying what I need December 21, 2014 05:58PM |
Re: Information needed before buying what I need December 21, 2014 06:38PM |
Re: Information needed before buying what I need December 21, 2014 08:02PM |
Re: Information needed before buying what I need December 22, 2014 07:55PM |
Re: Information needed before buying what I need December 22, 2014 08:42PM |
Re: Information needed before buying what I need December 22, 2014 09:35PM |
Ohmarinus
After reading on, it seems that this is the kit I need:
[jtechphotonics.com]
I have gotten a bit of extra money from second-hand things I've sold this month and can afford to buy this laser. It will be $384.49 including tax. So I would have to calculate how much extra tax I would have to pay, it probably will be another 100$ for the Netherlands... Hmm, maybe I have to find another product... I realize this is getting very expensive.
It will cost me €409 euros, this is $500 USD. Hehe, okay, nevermind, I will forget about this.
Can I directly run this laser through my Ramps 1.4 or do I need to buy additional parts? I've seen Cozmicray's lasercutter and he seems to use the 1.7W version, so I would assume that I can use this 2.8W laser with the same setup as Cozmicray.
The 1.7W version will cost me 306 euros, or 375 dollars.
Re: Information needed before buying what I need December 23, 2014 04:07AM |
My remark was for the $500 that Ohmarinus estimated. A random example of CO2 close to that price: [www.ebay.com]Quote
cozmicray
??? Where can you buy a CO2 laser rig (with optics, mirrors) for $335???
Re: Information needed before buying what I need December 23, 2014 06:02AM |
Re: Information needed before buying what I need December 23, 2014 06:13AM |
Re: Information needed before buying what I need December 23, 2014 04:18PM |
Re: Information needed before buying what I need December 23, 2014 05:19PM |
Re: Information needed before buying what I need December 23, 2014 05:29PM |
Re: Information needed before buying what I need December 23, 2014 05:41PM |
Re: Information needed before buying what I need December 23, 2014 07:28PM |
VDX
... this 1.5W/1.6W-diodes are older types, then used in the DLP-beamers, so pretty cheap.
The 2W-module with driver looks common enough so could be worth the price.
My own 2W-modules are in a similar price range ...
Laser diode
9mm TO5
Wavelength: 450nm ~ (Blue)
Power: max. ~ 3000mW (CW)
Recommended Max Stom: 2000mA
Threshold current: 200mA ~
Life: ~ 20,000 hours (at 480mA)
Re: Information needed before buying what I need December 24, 2014 04:01AM |
Re: Information needed before buying what I need December 25, 2014 02:49PM |
Re: Information needed before buying what I need December 25, 2014 03:06PM |
Re: Information needed before buying what I need December 25, 2014 05:56PM |
Re: Information needed before buying what I need December 25, 2014 06:23PM |
VDX
... look at the
This means, ye more current/heat, the shorter the life-time expectations, starting with 0.5A ...
And you'll need glasses specified for 445nm!
Re: Information needed before buying what I need December 25, 2014 07:23PM |
Re: Information needed before buying what I need December 26, 2014 07:14AM |
VDX
... have you more data for them? - looks, as if that's not meant for full protection, but only for 'adjusting' the laser beams.
"Full protection" glasses are less transparent (mostly orange when against 445nm) and more expensive than "adjusting" glasses ...
Re: Information needed before buying what I need December 26, 2014 01:29PM |
