What is the difference between these two lasers June 28, 2016 09:26PM |
Re: What is the difference between these two lasers June 29, 2016 03:10AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: What is the difference between these two lasers June 29, 2016 09:54AM |
Re: What is the difference between these two lasers June 29, 2016 10:32AM |
Flashsolutions
Thank you Viktor.
I have a couple of concerns still. I would prefer to use Repetier software on a RAMPS 1.4 board. The output would come from D9, the fan control, which is 12V PWM, but I have no idea where I would have control over the pulse rates and lengths.
Maybe I would need to use Marlin controller software? Not familiar with it. I assume the controller is where the pulse rates and lengths are defined?
Because the board outputs 12volts that would damage the diode. I am wondering if I could put a second driver in place that feeds the internal driver of the above mentioned ebay diode. The driver link is here... [www.ebay.com] This would allow me to use the higher input voltage from D9 on the RAMPS board, but I don't know if feeding the Diode with two drivers will work.
Re: What is the difference between these two lasers June 29, 2016 10:40AM |
Re: What is the difference between these two lasers June 29, 2016 10:59AM |
Re: What is the difference between these two lasers June 29, 2016 11:29AM |
Re: What is the difference between these two lasers June 29, 2016 11:41AM |
Re: What is the difference between these two lasers June 29, 2016 11:52AM |
Re: What is the difference between these two lasers June 29, 2016 12:06PM |
Flashsolutions
Found this post which addresses many of my same questions. [forums.reprap.org]
Think I read it earlier but did not look at the photos posted which are of the same diode I have been considering.
Still would like to know if inserting a second driver between D9 and driver of the laser will work.
Re: What is the difference between these two lasers June 29, 2016 12:10PM |
Re: What is the difference between these two lasers June 29, 2016 01:06PM |
Re: What is the difference between these two lasers June 29, 2016 01:23PM |
Re: What is the difference between these two lasers June 29, 2016 01:31PM |
Re: What is the difference between these two lasers June 29, 2016 01:33PM |
Re: What is the difference between these two lasers June 29, 2016 01:38PM |
Re: What is the difference between these two lasers July 14, 2016 11:11PM |
Re: What is the difference between these two lasers July 15, 2016 04:21AM |
Re: What is the difference between these two lasers July 17, 2016 06:35PM |
Re: What is the difference between these two lasers July 17, 2016 07:10PM |
Re: What is the difference between these two lasers July 17, 2016 07:23PM |
Re: What is the difference between these two lasers July 17, 2016 08:27PM |
