Which intensity laser Diode can cut 3MM MDF sheet? June 14, 2017 04:55AM |
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 14, 2017 09:41AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 14, 2017 07:43PM |
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 15, 2017 01:01AM |
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 15, 2017 02:27AM |
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 15, 2017 08:44AM |
o_lampe
It would help to blow compressed air in the cut. Otherwise cut 4-10 don't do much.
IMHO it's more about dot size than laser power. So better spend money for a small spot LD and a good lens.
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 15, 2017 11:03AM |
zee123
VDX
... could be done with a blue (445nm) 2Watt-diode in 5 to10 passes ...
Thanks Victor.
one more thing what if i use 3W or 5W diode? and what is life of Diode?
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 16, 2017 01:28AM |
Re: Which intensity laser Diode can cut 3MM MDF sheet? June 23, 2017 03:34AM |
