Diodes for cutting wood? February 26, 2016 05:35PM |
Re: Diodes for cutting wood? February 26, 2016 06:26PM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Diodes for cutting wood? February 26, 2016 07:09PM |
Re: Diodes for cutting wood? February 26, 2016 09:12PM |
Re: Diodes for cutting wood? February 27, 2016 04:09AM |
Re: Diodes for cutting wood? February 27, 2016 10:36AM |
Re: Diodes for cutting wood? March 02, 2016 10:02AM |
Re: Diodes for cutting wood? September 29, 2016 05:24AM |
VDX
... my thest show that the actually best single-diode solution for cutting wood is the 3.5W-diode - here the energy density and power is enough to cut 4mm plywood with 4 passes.
I'll estimate, for cutting in a single pass with 445nm you'll need roughly 10 Watts on a spot of 0.1mm - so either two combined 6W-diodes, 4 of the 3.5W-types, or a CO2-laser with >20Watts on a spot of 0.2mm ...
Re: Diodes for cutting wood? September 29, 2016 05:53AM |
Re: Diodes for cutting wood? January 31, 2017 07:18AM |
Re: Diodes for cutting wood? February 08, 2017 08:47AM |
Re: Diodes for cutting wood? February 08, 2017 09:25AM |
Re: Diodes for cutting wood? February 08, 2017 11:32AM |
Re: Diodes for cutting wood? February 08, 2017 08:16PM |
Re: Diodes for cutting wood? June 20, 2017 08:37AM |
