Oi will like to know the price and shipping to puerto rico
felixlaser Wrote:
www.sinjoelaser.com]
> Sinjoe Laser Controller AWC-608C with a advanced
> and stable colorful screen craft,to help you see
> the files directly and change any parameters
> without computer,High speed and beautiful
> ,directly present the engraving art .
> Product name:Sinjoe Laser Controller (Colorful
> Screen)
> Item:AWC-608C
> 1. Product Description:
> Ÿ A stronger AWC 608 enhanced version
> Ÿ World class laser cutting controller with
> colorful screen
> Ÿ Colorful Screen: can directly preview files
> and graphics on the 3.5 inch LCD screen
> Ÿ Change parameters freely: need no computer to
> change all controller parameters
> Ÿ Top stability and working speed and almost 0
> maintenance rate (Tested by more than 20,000
> orders over 4 years)
> 2. Features:
> 1. Super DSP technology 32-bit floating point
> high-speed control & computing core. The main
> frequency is up to 150MHZ.
> 2. Individual working state with Anti-jamming
> OC (optical coupler), upgrade by U disk for the
> latest patch.
> 3. Adopt advanced completed S-type accelerating
> and decelerating Calculation method, supply lines,
> arc&circle and B-type bar interpolation. High
> speed reaction with stable performance.
> 4. Whatever changes will be softer and more
> quickly, for the effective cutting with no
> sawtooth.
> 5. Network management and PC-communication are
> more convenient, safe and reliable.
> 6. With 128MB storage, it works independently
> form PC, which is useful for the quantities of
> engraving and cutting production.
> 7. 7. X/Y/Z/U 4 Axis can be in a high speed
> working state synchronously or independently. Z
> and U axis are idle and can be designed into
> auto-feeding system or up down table as you wish.
> 8. It’s suitable for servo motor and
> stepping motor with various motor drive systems.
> 9. Auto air blowing, auto focus,foot pedal
> switch ,water protection.
> 10. Support software and hardware limit
> coordinate protection.
> 11. Support double laser head with advanced
> double head approach movement cutting craftwork.
> It has separated power control.
> 12. Suitable for various laser source, from RF
> tube to CO2 glass tube.
> 13. Adopt Advanced PPI LASER control method, to
> protect the perfect edge cutting effect (e.g. wood
> edge cutting will not be blacked out.). Also
> lengthen the lifespan of laser source.
> 14. Support box cutting craft, a great
> improvement for saving you materials and time.
> 15. With a certain angle, the export line can be
> added by software, to ensure cutting seam position
> with a smooth and flat effect.
> 16. With small circle files the cutting speed
> can be changed flexible for the perfect cutting
> effect.
> 17. Can deal with different layers in one file.
> Each layer can be with an individual output power,
> output speed, working type
> (cutting/engraving/360-degree slope engraving),
> and automatic saving the related parameters.
> 18. Perfect power outage continued engraving
> function: the system has saved the record of
> real-time working status. When power off suddenly,
> your machine can still continue working and finish
> the task after it is restarted.
> 19. It presents the total working time and cost
> budget function. Input files with intelligent
> typesetting.
> 20. With cutting and engraving mixture working
> mode, it can finish different tasks all at once.
> 21. Freely dispatch our computer laser controller
> system-LaserCAD, CorelDraw, and AutoCAD directly
> output software.
> 22. Support files format: BMP, GIF, JPEG, PCX,
> TGA, TIFF, PLT, CDR, DWG, DXF, DST, DSB and etc.
> 23. With USB 2.0 interface, you can use U disk to
> in and output information.
> Warranty: 1 year
> Payment: T/T, Western Union, Paypal
> Package:
> ≤ 5PCS: a white carton with EPE materials for
> 1-5 pcs orders by express.
> EPE materials are at least 1cm thick to protect
> LCD panel and other parts from damage during
> transportation.
> >5 PCS: a bigger cube carton to save more
> express cost and full of EPE air Bubble to make
> sure the cargos is secured.
> For more details you can contact with
sales@sinjoelaser.com
