How to upgrade your cutting machine with a colorful controller?
May 26, 2013 02:02PM
Sinjoe Laser Controller AWC-608C with a advanced and stable colorful screen craft,to help you see the files directly and change any parameters without computer,High speed and beautiful ,directly present the engraving art .
Product name:Sinjoe Laser Controller (Colorful Screen)
Item:AWC-608C
1. Product Description:
Ÿ A stronger AWC 608 enhanced version
Ÿ World class laser cutting controller with colorful screen
Ÿ Colorful Screen: can directly preview files and graphics on the 3.5 inch LCD screen
Ÿ Change parameters freely: need no computer to change all controller parameters
Ÿ Top stability and working speed and almost 0 maintenance rate (Tested by more than 20,000 orders over 4 years)
2. Features:
1. Super DSP technology 32-bit floating point high-speed control & computing core. The main frequency is up to 150MHZ.
2. Individual working state with Anti-jamming OC (optical coupler), upgrade by U disk for the latest patch.
3. Adopt advanced completed S-type accelerating and decelerating Calculation method, supply lines, arc&circle and B-type bar interpolation. High speed reaction with stable performance.
4. Whatever changes will be softer and more quickly, for the effective cutting with no sawtooth.
5. Network management and PC-communication are more convenient, safe and reliable.
6. With 128MB storage, it works independently form PC, which is useful for the quantities of engraving and cutting production.
7. 7. X/Y/Z/U 4 Axis can be in a high speed working state synchronously or independently. Z and U axis are idle and can be designed into auto-feeding system or up down table as you wish.
8. It’s suitable for servo motor and stepping motor with various motor drive systems.
9. Auto air blowing, auto focus,foot pedal switch ,water protection.
10. Support software and hardware limit coordinate protection.
11. Support double laser head with advanced double head approach movement cutting craftwork. It has separated power control.
12. Suitable for various laser source, from RF tube to CO2 glass tube.
13. Adopt Advanced PPI LASER control method, to protect the perfect edge cutting effect (e.g. wood edge cutting will not be blacked out.). Also lengthen the lifespan of laser source.
14. Support box cutting craft, a great improvement for saving you materials and time.
15. With a certain angle, the export line can be added by software, to ensure cutting seam position with a smooth and flat effect.
16. With small circle files the cutting speed can be changed flexible for the perfect cutting effect.
17. Can deal with different layers in one file. Each layer can be with an individual output power, output speed, working type (cutting/engraving/360-degree slope engraving), and automatic saving the related parameters.
18. Perfect power outage continued engraving function: the system has saved the record of real-time working status. When power off suddenly, your machine can still continue working and finish the task after it is restarted.
19. It presents the total working time and cost budget function. Input files with intelligent typesetting.
20. With cutting and engraving mixture working mode, it can finish different tasks all at once.
21. Freely dispatch our computer laser controller system-LaserCAD, CorelDraw, and AutoCAD directly output software.
22. Support files format: BMP, GIF, JPEG, PCX, TGA, TIFF, PLT, CDR, DWG, DXF, DST, DSB and etc.
23. With USB 2.0 interface, you can use U disk to in and output information.
Warranty: 1 year
Payment: T/T, Western Union, Paypal
Package:
≤ 5PCS: a white carton with EPE materials for 1-5 pcs orders by express.
EPE materials are at least 1cm thick to protect LCD panel and other parts from damage during transportation.
>5 PCS: a bigger cube carton to save more express cost and full of EPE air Bubble to make sure the cargos is secured.
For more details you can contact with sales@sinjoelaser.com
Oi will like to know the price and shipping to puerto rico
felixlaser Wrote:
> [www.sinjoelaser.com]
> Screen)
> Item:AWC-608C
> colorful screen
> 2. Features:
> latest patch.
> sawtooth.
> effect.
> typesetting.
> output software.
> Warranty: 1 year
> Package:
> transportation.
