Re: Making PCB's with a diodelaser February 17, 2017 04:28PM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Making PCB's with a diodelaser February 19, 2017 08:41AM |
Re: Making PCB's with a diodelaser February 19, 2017 08:52AM |
Re: Making PCB's with a diodelaser February 20, 2017 08:40AM |
brunobasto
Hey @lukie80, keep us posted on your progress. It's looking beautiful. Do you have pictures of your results and printer? Maybe a video?
Re: Making PCB's with a diodelaser February 20, 2017 09:14AM |
lukie80
brunobasto
Thanks. And thanks to VDX for his idea, publishing and support.
So far I only removed the RC paint using nitro diluent. It looks OK although I seem to have some backlash issues. [attachment 90941 etched.jpg]. Next step will be drilling which will show if my PCB alignment was OK.
The printer I use is a cheap Prusa i3 clone with some minor improvements: Geeetech i3 Pro X. The biggest change I made was designing a quick fit carriage system which allows a quick change of tool heads (i.e. print head, laser head, mill head). There you can see the heads I use: Quick Fit Carriage and Laser Head. The precision of my printer is not ideal (see PCB ) and it is not rigid enough for deep or fast milling.
Re: Making PCB's with a diodelaser February 23, 2017 06:18AM |
Re: Making PCB's with a diodelaser February 23, 2017 06:54AM |
rastaman46
Would 2W laser penetrate FR1 Board???
Re: Making PCB's with a diodelaser March 08, 2017 04:52PM |
Re: Making PCB's with a diodelaser March 23, 2017 08:43AM |
VDX
... yes, I'm using (1:1:1) hydrochloric acid + hydrogen peroxide + distilled water.
Common spray-paints can withstand some minutes until they start eroding ... depends on temperature of the solution ...
For stone and other brittle materials I'll suggest lasercutting thin layers of previously laminated elastic sheets, remove the parts you want to mark and use sandblasting ...
Re: Making PCB's with a diodelaser March 23, 2017 08:57AM |
Re: Making PCB's with a diodelaser March 30, 2017 10:29AM |
Re: Making PCB's with a diodelaser April 20, 2017 02:08PM |
Re: Making PCB's with a diodelaser April 23, 2017 05:32PM |
Re: Making PCB's with a diodelaser April 25, 2017 06:01PM |
Re: Making PCB's with a diodelaser May 03, 2017 03:59PM |
Re: Making PCB's with a diodelaser May 04, 2017 02:39AM |
Re: Making PCB's with a diodelaser May 04, 2017 09:30AM |
Re: Making PCB's with a diodelaser May 12, 2017 06:29AM |
Re: Making PCB's with a diodelaser May 13, 2017 03:00AM |
Re: Making PCB's with a diodelaser May 13, 2017 09:44AM |
Re: Making PCB's with a diodelaser August 07, 2017 01:17PM |
Re: Making PCB's with a diodelaser August 21, 2017 10:18AM |
Re: Making PCB's with a diodelaser September 03, 2017 10:28AM |
Re: Making PCB's with a diodelaser October 15, 2017 01:09PM |
Re: Making PCB's with a diodelaser October 16, 2017 06:44PM |
Re: Making PCB's with a diodelaser November 04, 2017 01:11PM |
Re: Making PCB's with a diodelaser January 05, 2018 03:36AM |
Re: Making PCB's with a diodelaser March 31, 2019 10:18AM |
Re: Making PCB's with a diodelaser April 01, 2019 04:59AM |
Re: Making PCB's with a diodelaser April 01, 2019 02:22PM |
