Laser Diode temperature
Posted by Ohmarinus
January 15, 2015 05:59PM
Hey guys, so, finally got around to testing the L-Cheapo laser smiling smiley
I notice it's getting very hot, when I touch it with my finger after only 30 seconds of cutting, the element and laser are so hot that they hurt my finger. This is nowhere near 20-30º celsius. I'm afraid this is bad for the diode.
Now, I've already emailed the seller of the product, but I just want to be sure, this is not normal right?
http://www.marinusdebeer.nl/
VDX
Re: Laser Diode temperature
January 16, 2015 05:30AM
... no, definitely not normal!
But this is often the 'normal case' with this cheapish chinese modules - they normally overpower the diodes, with not sufficient cooling, to show their 'superior power' -- and calculate, that the resulting lifetime of only some ten to hundred hours (sometimes even only minutes!) will be an issue of the buyer sad smiley
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
January 16, 2015 06:43AM
I've contacted the seller and I'm told it should have a functioning overheat protection. If it malfunctions, I will get a replacement.
Meanwhile my CoreXY machine is performing flawlessly, only had trouble with setting up the endstops, but that's figured out.
I have more problems with the workflow, but I will start a new topic so that other users can find back the info easily if they have the same problem.
January 18, 2015 02:31PM
FWIW
Did a quick test on my laser diode
contact thermocouple on aluminum block around laser
time -- degree C
ON
0 -- 16.2
3 -- 28..4
4 -- 32.2
5 -- 36.7
OFF
7 -- 34.0
22 -- 20.9
I'll keep thermocouple on during next cutting run
confused smiley
